Question about Westinghouse Refrigerators
Fridge keeps freezing
Does anyone know if I have changed the thermostat and my fridge keeps freezing what it might be?
    Sergeant:
  • 202 Answers
If u change the thermostat and it keeps freezing the heater or timer are bad
Posted on Jul 24, 2009
2 Suggested Answers
  • 5 Answers
SOURCE: Idesit BAAN134 PSUK fridge keeps freezing food
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Posted on Nov 02, 2010
My fridge keeps freezing everything what is the best temp to have it set at. It is an aurora model RB411M3
I recommend moving the thermostat to the exact center position, unplug, then plug in the refrigerator. Wait 24 hours for the fridge thermostat to reset and to thaw automatically. Then, I recommend a fridge thermometer, available at most grocers or kitchen supply stores. If you can't find one, use a digital thermometer with a probe. Place the thermometer hanging from the center of the center shelf. Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Allow 24 hours for any thermostat changes.
Apr 08, 2017 | Refrigerators
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
I have abeko ap930 ,everything in the bottom 2 drawers in the fridge keeps freezing anyone know how to solve this?
it could be door seals ,not fitting tight all round(an air leak in the bottom seal will encorage ice to form on the floor) thermostat turned up to high(fridge temp should be plus 2 to 5c not lower or salad will freeze.
or a faulty thermostat.
pick one.
leave feedback
ta!
Jun 17, 2010 | Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
Jan 05, 2010 | Refrigerators
How to change the thermostat on a Hotpoint RLA30 fridge
It is behind the knob your are adjusting to change the temperature.
It is very easy for me. Don't know how easy for you and your electrician friend.
Apr 20, 2009 | Hotpoint RLA30 Compact Refrigerator
Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Mar 03, 2009 | Liebherr KELB 2840 Premium biofresh...
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Candy cpca291ffk fridge freezer
This is due to the failure of the thermostat device..hence its not controlling the temperature..If you are good at electrical appliance repair i can tell u how to fix it...Otherwise i advice you give it for servicing...Let me know what you have choosen..
Oct 18, 2007 | Freezers
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
476 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
