Question about Thermador Kitchen Ranges
Electronic ignition started clicking and won't stop
  • 530 Answers
You need a spark modual
Posted on Jul 24, 2009
Honda foreman 2000 450 won't start but fires sometimes with electric start when letting off button but does nothing with the pull start.help
Hi, Christina and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
honda trx450 foreman service and repair manual pdf
Honda foreman won start
http://www.hondaforeman.com/128-foreman-450/78283-foreman-won-t-start.html
Honda Foreman 450 wont start Help
Apr 17, 2016 | Honda Motorcycles
I have a 2001 ford focus zx3 I have no power at all ive replaced the battery, ground cable battery terminals went through the fuses, relay switch. It makes a loud beeping noise when I removed the fuse to...
Hello Genaro,
After looking on the CarComplaints com Car Problems Car Complaints Repair Recall Information website it became very clear that the major problem with your vehicle is the ignition key switch, which may be the problem with your car also! Click on the following link that is specific to your car & issue;
2000 Ford Focus Won Start
Good Luck!
Rich Lilja
Mar 20, 2015 | 2001 Ford Focus
Why won't 1981 suzuki gs 550 bike won't start after riding it and it's warmed up?
hi
glad i served a long time with wisco and used drag raced for them at one time
sounds to me that your ignition is to far retarded
which means the ignition will spark closer to (TDC)
top dead center
some people advanced the ignition 3 deg to stop the engine from smoking when they did away with 4 star fuel
and gave us unleaded fuel
doing this the performance is great and fast acceleration
but it also make the engine run hotter than normal
unless you have up jetted the carbs
and fitted a non standard exhaust system
the whole idea is get the fuel/air mixture in and out as fast as possible
if you still have points
take your points cover off and adjust your points baseplate
undo the three screws that hold it in place
and just move it about 3 deg towards the rear of the engine
or may be you have a electronic ignition fitted
if so do the same thing
and advance the ignition 3 deg
hope this works for you
ride safe
Sep 18, 2017 | 1982 Suzuki Gs 550 L
Starter clicks won't start after hot
Hi Djgoshen, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Mar 14, 2012 | 2000 Harley Davidson FLSTC Heritage...
Start car just one click but no start
Sound like u have a bad solenoid or it could also be the ignition backing as they like to give problems
Mar 06, 2018 | Toyota Camry Cars & Trucks
1999 Dodge Ram Conversion Van won't start. After many attempts the battery finally died but before it did it was making a clicking noise when we tried to start it. My husband saw a spark under the...
I hope that you have disconnected the battery fire could happen relay click's but will stick at drain could be the fuel pump you hear with the continuse click you might have a shorted starter.I think thats the first place to start.A bad ignition switch will cause this to happen sometimes?
Jan 11, 2018 | 1999 Dodge Ram
Electronic iginition won't stop....
bad ground or switch assembly.
Jul 12, 2008 | Cooktops
Kitchen Ranges Logo
365 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
