Question about Okia 420w UL Approved ATX Computer Power supply (OKIA420ATX) Power Supply
Dead Computer computer will not power up - it has an OKIA switching power supply model OKIA-420ATX ... help
    President:
  • 2,185 Answers
Is the fan of the power supply still circulating?
If not, your power supply needs replacement.
Posted on Jul 24, 2009
I have a Okia 420ATX power supply. I had it
Based on the additional information that the power supply fan turns on for a few seconds and then goes off indicates to me you have a motherboard or processor problem. I would have a service center check the computer for you.
Feb 03, 2010 | Okia 420w UL Approved ATX Computer Power...
Need fan for Okia 350 ATX
its the bearings in the fan starting to pack up, best way is to stop the fan spinning when its on with a small pencil and this should re- align the bearings in the fan and stop the noise, you will need a new powersupply the fan is on the way out, just a temp. fix for you to stop the irritating noise
Jan 28, 2010 | Okia 350w UL Approved ATX Computer Power...
I have an OKIA 350ATX power supply in my system that I need to replace, but I cannot find one. Could I use one of these 450W ones? http://www.bccpc.com/bccpc/power_all.htm
as long as your using atx and your system isn't one of those micro systems that needs a special smaller power supply then yes you can use that one
Oct 15, 2009 | Okia 350w UL Approved ATX Computer Power...
I have an OKIA power supply that was installed last September. The fan has stopped working allowing the tower to overheat. Is this model OKIA 350-ATX still in warranty?
Yes, the factory provides a 1 year warranty. Since you installed it some 11 months ago I suggest you contact them asap. You'll probably need to provide the serialnumber to them as part of the procedure.
Okia is not actually the full name, the company that makes them is called Broadway Com Corp and their (powersuplly) website is: http://www.bccpc.com/bccpc/power_all.htm
The contact information can be found at: http://www.bccpc.com/bccpc/contact.htm
Aug 12, 2009 | Okia (OKIA550WP4PS) Power Supply
Friends custom-build PC has no power
Seems reasonable. Take the motherboard out of the case,  first to see if it will work outside of the case. Sometimes boards short to the ground due to a screw or other metal getting between them and the case. Try to run it with as little hardware hooked up as possible. You don't even need a hard drive to post the BIOS.
Mar 12, 2009 | Okia 420w UL Approved ATX Computer Power...
I have a okia 500atx power supply. When I attempt to turn on the computer, it will stay up for about 3 seconds then turn off. is the power supply the problem?
CHECK THE FAN REMOVE ANY DUST AND SPIN THE FAN PLUG IT IN AND TURN IT ON IF SAME PROBLEM THAN THE FAN IS BAD IN THE POWER SUPPLY AND YOU NEED A NEW POWER SUPPLY TAKE IT WITH YOU WHEN YOU GO TO THE COMPTER STORE FOR A NEW ONE
CANDYMANGANDY
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
My computer turns on but wont turn hdd all the way on it starts then clicks and stops goes to a black screen. and there is a smell coming from the computer. i put the hdd in another tower and it worked.....
If you have a standard atx case then any standard atx power supply should work. Yes you can upgrade to one with more wattage as long as it has all the connectors you need. Hope this helps.
Dec 24, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Busted component
Getting a schematic is rather doubtful. You might be able to get a general idea of the circuit from somewhere on the 'net.
Was the power supply dead?
ATX style power supplies have both a standby and main section. The standby supplies a low current +5 volts to a small portion of the motherboard.
If the component failure is in this section, this standby voltage will be missing or incorrect, and the computer will be dead- won't power on at all.
I've seen a number of catastrophic failures in this standby circuit, and repair isn't suggested or economically feasible, especially as some parts often poof beyond identification.
When the pwr button is pushed, the main section comes on, and supplies +5 (Red wires), +12 (Yellow wires), +3.3 (Orange wires), -5, -12. Look here for this info http://pinouts.ru/Power/atx_v2_pinout.shtml
Voltages are precisely regulated, and any substantial deviation (more than a few 10ths of a volt) indicate a problem, especially on the +5 & +3.3 lines.
Jul 07, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Fan
Hi replace the fan by opening the power supply with a new fan if your power supply is under warranty period still get it exchanged.
May 19, 2008 | Okia 250w UL Approved ATX Computer Power...
Power Supply Warrenty
I couldn?t find a web site for Okia either; however, I did note that the venders that sold them usually guaranteed them for one year themselves. I would at least try that route, that and not buy Okia power supplies. There are lots of stories and physical examinations of how poorly they are designed and manufactured.
Sep 19, 2006 | Okia / 450-Watt / ATX / 80mm Fan /...
Computers & Internet Logo
241 people viewed this question
Top Okia Computers & Internet Experts
David Payne
David Payne
Are you an Okia Computer and Internet Expert? Answer questions, earn points and help others
