Question about 2wire Computers & Internet
2Wire Home Portal 1100 for AT&T DSL connection problem
I have a 2Wire Home Portal 1100 as the gateway for my home network. I connect my computer(s) and my brother's computer (Wirelessly) through a WRT54G Lynksis router. I recently downloaded Cisco Network Magic as the easiest means of streamlining my home network. Now I cannot get a stable Internet connection even though my Home network seems to be working. What am I missing?
  • 404 Answers
HI! read your posting regarding the situation that your experiencing.. If before you dont have any problem regrding your connection with out the cisco network magic. I suggest that before you install the cisco network magic. you should get the full version not the trial version, there is a limitation of setting up the trial version.. Cisco network magic is a plug and play and easy to setup if you get the full version. I dont see any problem regarding your connection with the 2wire and the linksys router, becoz you mention earlier that hime network is working and you can connect to the network and the internet..
Posted on Jul 25, 2009
I have my computers and laptop networked through my 2wire Home Portal 1000SW modem and am trying to connect my Coby Kyros MID8024 Tablet through wifi. The tablet finds my 2wire network but seems not to...
1st make sure that your using the proper WEP key (Wireless Password) 2nd make sure that their wirelessly compatible SW is a wireless b compatible to eliminate this issue you may also disable your WEP
majority of new technology uses wireless G and N
this wireless modem is a little bit outdated:
Data Link ProtocolEthernet , IEEE 802.11b , HomePNA 2.0 , HomePNA 1.0 , USB
see for your tablets protocol if this would match:
Aug 28, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Need to find my wep key for my AT&T 2 wire 2700HG-B DSL router
The Default Wep Key is the 10 digit key located on the bottom sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simly accessing the router. I've listed the steps on how to access the router incase the Network Key on the sticker is not working.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya
Jan 31, 2011 | 2wire (2701HG-B) Wireless Router
I recently upgraded from my 2wire DSL to Uverse. My older laptop with the 2wire card and the home portal fins the new network but only runs at 11 mbps. Where my other laptop with the newer 2wire software...
That means the older 2wire card was a B model adapter, which can only run at 11mbps. The other laptop most likely has built in wireless or some other adapter in it that runs on the G model, which is 54 mbps. There is no way to fix this issue, other then aquiring a new wireless adapter for your older laptop.
Jun 29, 2009 | 2wire HomePortal® 1800HW Router...
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Connect panasonic bl-ca10 cam to a 2wire home portal 1800g
Try using WEP instead of The WAP protocol.
It worked for me.............
Jul 06, 2008 | 2wire HomePortal 1000HW DSL Modem and...
2wire HomePortal replacement necessary?
how bout customizing the wireless settings of your 2wire first for a more stable connection. like change the wireless name from it's default and enable a wireless security. you can also change the wireless channel to minimize interference from other wireless device near your area.
if you have done that already, try to upgrade the firmware of your router to check that it's not a firmware issue.
if you have done everything to solve your concern, it's better to get a replacement.
i believe your home portal is a gateway. if so, you also need to have a gateway to replace it and a router is not sufficient.
as long as your laptop has a wireless card installed, you don't need any other equipment
hope this'll help you.
Jun 03, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Hg1000 home portal
do you mean the modem's ip address?
http://homeportal
http://homeportal/setup
http://192.168.1.254 (software version 3.7.x and higher)
http://172.16.0.1 (software version 3.5.x or earlier)
hope this is the one you're looking for...?
Apr 06, 2008 | 2wire HomePortal 1000HG DSL Modem and...
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Can't connect one laptop
Ok this is a simple, but difficult fix at times. I need to know if the other laptop is used in and or outside of your home? In addition I need to know if you have security like a WEP or WPA setup? Do you have a home network setup using this router/modem? I may have other questions, but these I need to know in order to give you an exact answer!
Nov 25, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
514 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
