Question about Delta & Single Handle Shower Faucet
Water does not come from the shower head - Delta & Single Handle Shower Faucet
    President:
  • 1,273 Answers
If your showre head has an external adjustment (usually on the face of the head) make sure that it is opened. Shower saver type valves have a push button on the pipe from the wall to the showerhead, usually close to or are a part of the showerhead. Make sure that it is opened, if you have one. Once done, remove the shower head and turn the water on. If you get water, look into the shower head. Most come with a water restrictor and it can come out of position and block the passage of water. The restrictors can vary in appearance, but usually they consist of a rubber washer and plastic disc, and are in the back of the showerhead where it unscrews from the piping from the wall. If you can get water without the shower head on, but no water through the showerhead, you can take it apart and look for restrictions or just replace it. If you cannot get water after all that, the problem is in your faucet or piping. Most Delta single handled faucets that I'm familiar with have a spring and cup washer valving arrangement. Those equipped with scald gard are somewhat more difficult to work on. Parts are available from H/Depot, Lowe's and similar. Hopefully the problem is in the showerhead proper, and not in the valve.
Best 'o luck, --W/D--
Posted on Jul 24, 2009
Where can I get a shower head that doesn't restrict water flow?
If your problem is low pressure, your best bet is a pump. not sure if you can get them where you are. Are you in the USA?
Try Canadian shower heads.
Shower Pumps High Quality and Performance bathstore
Dec 06, 2015 | Home
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape.
First and foremost, read the install instructions that come with the new shower head...
After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water.
Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube.
Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench.
You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall.
To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head.
Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently.
Here's a nice short video on the subject, illustrating my instructions: http://youtu.be/fiv4Zq9v4co
Jul 27, 2014 | Delta Faucet Home
Triton shower faults
If its a trickle occasionally its normal, when you turn off shower the water is still in pipe right up to shower head, it cools down, contracts and backs away from the head, when house gets warmer water expands up to the shower head and trickles out.
Dec 14, 2013 | Home
Little water comes out my shower head when I take a shower, should I call a plumber, or is this something that I can fix myself?
remove the shower head. and if the water flows normal, its a clogged up shower head. if takeing a shower and the diverter valve goes bad. water will come out of the spout. check out shower head to see if its clogged. sometimes you can soak the head in a good cleaner and it helps it. but if its the showerhead thats plugged. you can always put a new one on also. good-day !
Jan 10, 2012 | Home
Water fails to flow through shower head although the bath and sink taps work
unscrew the shower head counter clockwise. Most shower heads have a wire mesh screen built in. remove it and wash out with water. Before re installing I would turn water on to be sure your water is reaching the shower head. If not your problem is at the water valve
Apr 14, 2011 | Home
There is no water coming out of the shower after insulation
To clarify your question, are saying that you just had a new water heater installed in your house and the shower head in the bathroom can't get water through it? If that's what you meant, the water restrictor in the shower head is plugged with sediment. This often happens during water main shut offs and then turned back on. It shocks the sediment on the inside pipe walls. The first places it affects are shower heads and faucet aerators. Remove the shower head and clear the clog or replace with a new shower head. If this is not what you meant to say, then rewrite your problem.
Feb 19, 2011 | Water Heaters
Shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
May 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
No water coming out from the shawer head
Welcome to Fixya.com
If I understand you correctly your not getting any water out of your shower head .It could be your shower head is clogged,
or your diverter is bad. Diverter takes the water up to the shower head.
Nov 25, 2008 | Home
Delta & Single Handle Shower Faucet  Logo
299 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
