Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune pad keeps freezing up on me
I was just listening to music and i always put it on hold and then all of a sudden the pad dosnt work and i thought it was on hold but it wasnt so then i pushed the back button and it worked but the pad just didnt work. I had a code for it and it didnt work at all. Then i tried taking it appart but the screws were to small so i ended up not taking it appart then i turned it on again and it worked. So i was playing with it and i turned the touch off and now its just on the click thing and then the third time i turned it on it froze on me again whats going on this is so stupid that one guy might be right it might be a virus but what ever it is its annoying and im tired of it i spent 200 on that thing and i dont want it to break on me ive had it for to long to replace it so what do u do?
Want to put music back on my zune,it wouldn't sinc,
May have to reset the zune to factory default settings...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Mar 12, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune freezes and says contact support
in order to fix this . you have to restart the device. to restart the device you press and hold back while also pressing and holding the top part of the zune pad until screen goes blank and zune logo appears this should work. if contact support comes back up try restoreing the device.
for more info on how to restore the zune go to zune.net/support and press technical issues and a list with how to fix any problems will appear
Jan 09, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune freezing
You may read this to solve the problem. here is a link
http://tech.yahoo.com/news/pcworld/20081231/tc_pcworld/microsoftsaysleapyearbugcausedzunefailures;_ylt=AglElnv.sPm6b9FZIubqw68azJV4
Jan 02, 2009 | Microsoft Zune JS8-00001 Digital Media...
''This item is missing or can't be played.''
I think your music got corrupted so you have to download them again
Nov 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Won't turn on
well this is a very serious problem it could be caused by age or by draning the battery a couple of times plug it in ti ur computer and see if the program recognizes it if not then u are srewed if it does refrsh ur zune by rasing everything and then putting everything back. or try pressing back and up of the pad
Oct 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune
If it freezes up hold the pause button and turn it off, then hold down the back button and up on the keypad and it will restart. If for some reason it keeps freezing constantly I suggest you contact zune.
Oct 26, 2008 | Microsoft Zune JS8-00001 Digital Media...
80 GB Zune will not respond.
http://support.microsoft.com/kb/927001/?sd=zune
try this page it gives you intsructions on how to reset your player and to re install the software
Aug 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30GB zune freezes up when stwitching between songs
MORE INFORMATION loadTOCNode(1, 'moreinformation');To restart the Zune device, follow these steps: 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position.
2. Press and hold the Back button zune_button_back.gif while you press the top of the Zune pad.
Jul 23, 2008 | Audio Players & Recorders
Zune
To reset the zune you must press and hold the back button and the top part of the zune pad. Other parts of the zune pad will not work.
When plugging the zune into your PC does the PC detect it (device manager -> portable devices). You should hear the ding sound of hardware connecting.
If it is connecting to the PC and is not detected by the software than it is likely a permissions problem. Right click the software icon and choose run as administrator.
If it is not detected by the PC than check your usb cable and make sure your zune is charged and not frozen.
May 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
Music stops and zune freezes up
uhm i think i may have found your solution, that is if your using limewire or some client of the sort, i synced my zune while the program (limewire) was on and downloading music and i had the same problelm you did so i simply deleted all my music and put it back on the zune while limewire was off and now it works fine, i have an 80 gig btw if that matters
Feb 10, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
173 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
