Door light flashes 4 times and can hear 4 clunks?
I went to use my washing machine this morning and the door light would flash 4 times and once i pressed start button i could hear 4 clunks and the machine would not start. The power also went out last night while the washing machine was switched on but not in use.
  • 221 Answers
First measure the door lock, make sure it's fine, then ensure that there's current flowing towards the door lock. if it'll trip all the electricity out you'll need to ru very close inspection or to replace the main circuitboard
Update me about your progress
Posted on Jul 25, 2009
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Door lock and extra rinse light flashes
is it the tub that clunks?was it very noisy in the spin cycle?if so the spider gear is gone and it would be cheaper to replace the washer.you should only be adding two tablespoons of soap that's it,alot of people use to much soap and it eats at the spider gear,if you look inside the tub at the back wall you'll see a piece sign,that's the gear located on the back of the tub
Nov 09, 2017 | Washing Machines
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Apr 27, 2010 | Zanussi FS1455W Front Load Washer
Red light about door icon flashing
Sounds like a door lock problem. May just be a weak spring in the door handle which helps push the door lock pin against the contacts in the door lock switch. If you open the door and push on the pin or operate the handle the pin should return positively to its closed position, if very weak return then spring wants replacing. Take door apart to gain access to handle and spring and replace spring if broken.
Feb 14, 2010 | Washing Machines
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Nov 07, 2007 | Washing Machines
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Oct 17, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
