Question about Garmin Rino 120 2-Way Radio
Garmin 120 just dies
My garmin Rhino120 will only stay running for a few minutes, then it get a line across the screen and dies.
  • 9 more comments
  • Hunterguy Nov 21, 2007
    I'll try these thanks
  • Hunterguy Nov 22, 2007
    Sorry-nope that didn't work.  Is there someone who fixes these, and is it worth it?
  • richjohns007 Aug 15, 2008
    my rhino 120 runs normal for a few minutes then shuts off with a line across the screen
  • Anonymous Oct 01, 2008
    works for 2 minutes, acquires satelites then dies (line across a blank screen). need to remove the batteries to restart.
  • Driver_851
    Driver_851 Oct 02, 2008
    Rino 120: Not used for 12 months, never damaged or impacted, fresh batteries, installed, unit functions perfectly, contrast is perfect, then 2-3 minutes later, unit freezes and screen blanks out with just a single horizontal line 1/4" from bottom. battery removal required to regain any control or functionality.
  • Anonymous Oct 03, 2008
    will try the solution
  • mtdoom Oct 22, 2008
    Having the same problem with unit locking up and showing line across screen after just a few minutes of normal functioning.  Even with power adaptor hooked up it does this so power loss is not the problem.
    Garmin wants $130 flat fee to repair that is way too high when new Rino 120's are under $200 now.
  • mastrand9 Nov 08, 2008
    Same problem for both Rino 120 and Rino 110: a couple minutes of good performance for both GPS and FRS/GMRS, then dead unit with single horizontal line.
    Tried the following:
    fresh batteries and confirmed electrical contact;
    fresh batteries plus connection to Garmin 12Vdc adapter;
    no batteries, Garmin 12Vdc adapter.
    When the Rino finally (mysteriously) reawakens after power downs through disconnection and/or battery removal, there is no problem for several days.
  • Anonymous Nov 16, 2008
    Same problem with the GPS shutting down for no reason and a line across the screen. Tried everything everyone has offered except the WAAS disable. I to hope Garmin reads this and gets it fixed.
  • Anonymous Mar 13, 2009
    when I turn on my rino 120 a dark line runs horizontal across the screen. Then shortly thereafter dies.
  • elkbound Mar 13, 2009
    I have a Rino 120 and when I turn it on, it locks up and shuts off.
    With it off, a horizontal line remains about 1/4 inch from the top of the screen. I've read some of the remedies, nothing has worked.
    I've liked my garmin up to this point, but if the repair from Garmin is $130.00 and a new one is $200.00, the repair is too costly. I also wonder if the problem has been addressed on newer models.
    Problem Solver:
  • 13 Answers
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Posted on Oct 02, 2008
  • 22 Answers
have you put fresh batteries in
are they the right way around
are the 2 metal spring clips tight up against the batteries
try bending them (al little) to make better contact
has the unit had any water in/on it
is the mic button pushed down and draining the batteries too quickly
Posted on Nov 21, 2007
Turn on rino and with a five minutes the batteries go dead
Posted on Aug 31, 2011
My rino 120 shuts off by itself
Posted on Dec 08, 2010
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Garmin Edge 305 will power off in a min or 2 riding in afternoon
This is a generic problem with the 205 and the 305 go to MTBGurublog and look up 305 problems there is a blog that shows how to open and fix it
Jul 07, 2009 | Garmin Edge 305 GPS Receiver
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Garmin GPS 152
I had the same problem so I replaced my 152 with a spare unit. It did the same thing. This led to believe it was the cable. I removed a few kinks and a bend at the unit; and it seems to be fine. Seems too simple and the bends were not that severe, but it is working (for now).
Aug 24, 2008 | Garmin GPS 152 GPS Receiver
XB360 Screen colour changes and then disappears
Could possible be your television.
Or maybe your Xbox is overheating.
Try placing your Xbox in a cool spot, direct a fan at it, etc.
Or try getting a new TV or Xbox.
Jun 29, 2008 | Microsoft Xbox 360 Console
Replacement screen for my garmin rhino 120
Hello joewilly31,
It looks like Garmin offers complete factory overhaul for out of warranty Rhino120 units for $99. For complete details on how to get an RMA number and ship the unit to Garmin for repair go to their website at:
While it may also be possible to purchase parts from Garmin directly, I would recommend against attempting to repair the unit yourself unless you a lot of experience working with and repairing surface mount electronics devices.
Hope this helps.
"Go Ahead. Use Us."
Jun 10, 2008 | Garmin Rino 120 2-Way Radio
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Garmin Rino 120 2-Way Radio Logo
486 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
