Meaning, if I lower the room temperature down in the room where the TV is, I am able to power on and off TV, as normal, with no blinking blue light issue. However, when the room temperature is warmer (~ 70 degrees F) and the set is turned on/off then, the issue with the blinking blue light is encountered. I am aware that it has been previously determined that a bad IC Regulator is the root cause for this issue. But shouldn't the issue be constant, without regard to the room temperature?
SOURCE: Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius. most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
SOURCE: possible thermal fuse problem.
I too, took off the back of my Sony TV after I started getting red and green shadows (called retrace lines) around words and people; and blew out all the dust inside hoping that would help. Ironically, I discovered that most problems with rear projection TVs are due to a malfunction located in the bottom FRONT panel, accessed by taking off the front speaker panel and then a wooden panel after that to access the circuitry, specifically this little black box with 6 screws on it. Go to www.SomeLifeBlog.com and this site has photos how to take off the front of the tv and instructions how to fix some common problems that repair people will charge you $300-500 to fix. This man, his instructions, photos, and website were a godsend. Good luck.
SOURCE: I have a hunter 44260
probably the temperature in the area where the thermostat sensor is placed is hotter ...so .if you want a higher temperature ..just set it with 5 degrees higher..and see what 's happening ..I think this will make it get to 70 ..
SOURCE: 1998 GMC Jimmy will not start in temperatures below 70 degrees.
There is a much richer fuel mixture during a cold start, the colder the engine the richer the fuel mixture
retarded ignition timing causing the fuel to burn for a longer period of time makes the engine heat up faster
anything that doesn't allow the mixture to be properly metered, like vacuum leaks, bad temperature sensors, or O2 sensors, MAF or MAP sensors, bad EGR valves or PCV valves hoses or tubes,
and or
anything that will cause the fuel mixture not to burn properly, like worn spark plugs, or any other ignition part, wires, cap, rotor, timing, compression, will cause poor start or no start conditions that are worse in lower temperatures,
also low voltage, week battery, slow cranking of the engine can also cause hard to start conditions
The
Standby/Power light of the TV blinks when there is any internal malfunction in
the TV. The self-diagnostic function of the TV will cause the STANDBY light to
blink or flash when the television detects an issue. The number of times the
STANDBY light flashes corresponds to a specific issue.
Few
examples are given below; some of the issues may be resolved without the need
for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a
power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your
set. The set will need to be serviced to allow a technician to determine the
specific issue that needs to be repaired. If the power light flashes three
times in sequence in a Lamp TV, the lamp cover is not securely attached.
Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power
problem.
6 blinks: - This indicates that there is some kind of audio problem with your
set.
7 blinks: - This indicates that there is a temperature problem with your set.
Please check to make sure that the air vents on the sides and back of the set
are not blocked or clogged and there is adequate ventilation around the
television. We recommend that you check and clean the vents periodically to
make sure the set receives adequate air flow. If the problem continues, the set
will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your
set. If the flash sequence is not listed above or the light continues to flash,
follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If
the television is plugged into a power strip or surge protector, remove it from
the power strip or surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge
protector and not the television.
If
the issue continues to occur, service may be required.
Thanks
for using Fixya.
The
Few
for service.
problem.
set.
If
If
Thanks
for using Fixya.
The
Few
for service.
problem.
set.
If
If
Thanks
for using Fixya.
The
Few
for service.
problem.
set.
If
If
Thanks
for using Fixya.
The
Few
for service.
problem.
set.
If
If
Thanks
for using Fixya.
