SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
SOURCE: LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
SOURCE: RF263 series Samsung Refrigerator just began
Hi The sound comes when there is ice build up around the fan
and the fan will hit it causing this sound. You can try to leave it unplugged
for around 4-24hrs and also make sure that the area near the back is clear so
that airflow can get through. If the issue returns then replace the thermostat.
Hope this helps...please post back for further assistance. Daniel
