SOURCE: Frigidaire Affinity Washer beeps & won't spin
The drain filter is clogged. I had the same problem. There is a filter inside the "drain boot" (black) that comes from the drum to the drain pump. Mine was completely clogged with money, lint, etc..
SOURCE: My front load washer affinity pauses 3 or 4 times during a cycle
the unit is waiting for something,,,like water ,,,or a slow drain..you must see where the unit is ,in the cycles,,and make sure that action the unit is trying to do is able to do...onthejob
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hey friend, I appreciate your post!
From my understanding your Frigidaire washer, LTF7000ES0, will not complete a cycle and the display will also go blank. It sounds like it could possibly be a problem with your control board, drawer, or lock switch. Since it could be any one of these issues I would recommend having a professional come out to your home and repair your washer. -Matt
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
