Question about Lisle Fuel Filter Disconnect For Gm
Where is the fuel filter located on a 1994 lexus ls 400
  • 10,515 Answers
The fuel filter is located behind the back seat...there is a 9" access port in the center of the fuel tank behind the back seat. located in the center of the open port you will see a fuel hose with some hose clamps....the 3 semicircular bolts that line the bottom of the portal anchor the bracket that holds the fuel filter mounted deeper in the fuel tank.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 24, 2009
Where is the fuel pump on a 1994 lexus ls 400?
The fuel pump is inside gas tank behind the back seat unscrew the only top that's there and it is inside the gas tank. You will have to remove your back seat to gain access to fuel pump. Fuel tank is located in trunk. No need to take fuel tank down. Click this link for full details and procedures:--- http://technoanswers.blogspot.com/2011/06/how-to-replace-fuel-pump-on-lexus-ls.html ----------- For fuel filter replacing, click this link:--- http://technoanswers.blogspot.com/2011/06/how-to-replace-fuel-filter-1994-lexus.html ----------- For timing belt and water pump removal and installation, click this link below:-- http://technoanswers.blogspot.com/2011/06/how-to-change-timing-belt-and-water.html ------------ For coolant flushing and filling, click the link below:-- http://technoanswers.blogspot.com/2011/06/how-to-drain-and-fill-coolant-on-lexus.html -------------- This all procedures should help.Thanks.Helpmech.
Jun 02, 2011 | 1994 Lexus LS 400
Need to change the fuel filter, can you show me were the fuel filter is on Lexus 1991 400 LS
hello there:
the fuel filter is going to be located under the car along the frame on the driver side you will need to jack the car up and look for a silver in color filter you may need quick disconnect tool to remove the the fuel lines from the filter the filter should have a big hose clamp around it hope this helps you out please leave a review thanks sincerely D.Jones
Jun 05, 2010 | 1991 Lexus LS 400
Need to locate fuel filter on 93 ls 400 lexus
under the car in front of the rear wheel on driver's side
Feb 28, 2010 | 1993 Lexus Ls 400
Do I need to drop the fuel tank in order to change the fuel pump on a 1994 Lexus LS 400?
yes you do, here are basic instructions for any in tank fuel pump. also remember to replace the fuel filter as well or warranty on pump is voided.
http://www.aa1car.com/library/fuel_pump_replace.htm
Nov 12, 2009 | 1994 Lexus LS 400
Hi i got a lexus LS 400 1998 and my starter die
the starter is located in the valley under the intake manifold. you must remove the intake to access the starter. its a pretty involved job. when reassembling take your time and make sure that every wire is plugged in and every vacum line is connected.
Nov 09, 2009 | 1994 Lexus LS 400
How to replace fuel filter on 1994 lexus gs300
you first find the fuel pump fuse then allow to run the engine then remove the fuel pump pressure fuse, immediately engine will stop, this is to reduce the fuel pressure in fuel lines, jack up the vehicle fuel filter is located under the car just infront of rear side driver tire remove the old one and fix the new.
Nov 03, 2009 | 1994 Lexus LS 400
Not running right
Verify the air filter canister for any foreing objects, change spark plugs, wires and fuel filter.
Jul 20, 2009 | 1994 Lexus LS 400
1997 Lexus LS 400 Fuel Filter location
The fuel filter is located under the vehicle on the left side before the rear axle.
Oct 13, 2008 | 1992 Lexus Ls 400
1992 Lexus LS 400
I was told there is no fuel filter
Jul 23, 2008 | 1992 Lexus Ls 400
94 Lexus LS 400 FUEL FILTER LOCATION ?
Fuel filter is located on the right side by the rear tire. U will have to get on the ground or jack car up to do it.
Jun 30, 2008 | 1994 Lexus LS 400
Lisle  Fuel Filter Disconnect For Gm Logo
85 people viewed this question
Top Lisle Measuring Tools & Sensors Experts
Billy Mac
Mai Lor
Prariehog
Prariehog
Are you a Lisle Measuring Tool and Sensor Expert? Answer questions, earn points and help others
