Question about Frigidaire HV2736B Kitchen Hood
Unit will sometimes not turn on
Intermittently, the unit will not turn on. Can push the switch and nothing. Then I'll push the switch a few times and I can hear something electrically happening, but still the hood will not rise nor will the blower fan turn on. Then I can push it a few more times, finally, the blower will slowly spool up and the hood will finally rise.
Do I have a motor slowly going out? What other issues could be on the horizon? The unit is only 2 years old.
  • Anonymous Jan 10, 2008
    Unit won't rise when the switch is pressed. when we manually lift the unit out, we can hear a sound as if a motor is trying to start.
  • 833 Answers
NASCAR...I'm thinking more like the switch. If you can, with the power off gain access to the switch wiring. find the lead that goes to the power and the motor. Connect them directly (you might need a paper clip). Tape it all up securely and fire up the power. If it will know about the switch...if not, you might look at the motor. By the way...check that motor should turn easily when you give it a spin. Motors of the type used in fans generally don't degrade in performance unless they get gummed up with kitchen grease. Clean the grease off with WD 40.
Posted on Dec 11, 2007
M y dc 07 won't turn on I've plugged it in pushed the button and nothing...I waited a few days and tried again nothing no power there was no problems beforehand
Hi Jodi .
Dyson has a very good customer service .
I had problems with my pull along ball type dyson and it was the power switch. I replaced the power switch but replacing the switch may be beyond your capabilties or it could be the motor and this might void the warranty on the unit. plus you need special torx drivers to unscrew a dyson.
Oct 25, 2016 | Computers & Internet
I do not have any turn signals or hazard light on my 2000 ford focus zetec how do i correct this
There is a flasher unit that controls both the normal indicators and hazard flashers, on a 98 ford escort it is fixed to the base of the indicator stalk switch, if you remove the shroud that covers the switches around the top of the steering column you can see the flasher unit, usually it is black and just plugs in to the bottom of the hazard and indicator switch. The unit should have an ignition supply to it as well as a perm ant supply when the hazard switch is pushed down. Sometimes these switches get sticky contacts so if you bang the switch on and off a few times it can sometimes make the contacts work and then then all the indicators start working again.
May 01, 2014 | 1998 Ford Escort
Coffeemaker on/off switch works intermittently. How do I remove the front panel to access the controls?
I have a Cuisinart coffee pot also and am encountering the same problem. There's nothing wrong with the brewing element, etc., but increasingly often, nothing happens when I turn the switch on. At times, if I leave it alone, it will come on--sometimes an hour or more after I switched it on. At others, if I keep trying, it eventually switches on.
My best guess is that the on-off switch is worn out or has corrosion/dirt on the terminals. I, too, am trying to figure out how to disassemble the unit. Once I do, I will post details here, along with what I find inside and whether I was able to repair it.
Good to know I am not alone. This must be a quirk of Cuisinart's coffee pots.
Mar 08, 2014 | Cuisinart DCC-1200 Coffee Maker
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
How do you reset a Magellan 1700 GPS?
FAQ on your unit says this.
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button If your unit has a Push Down Power Button for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
If that doesn't work, contact them direct. sometimes they have to install clean firmware.
MagellanGPS Technical Support Consumer Sales Customer Service
Apr 08, 2017 | Magellan Roadmate 1700
I have a Kenwood stereo integrated amplifier R-42XL that I bought 25 years ago. It has served me very well and still does intermittently. Sometimes when I plug into the mains the red light on the volume...
our company has always said anything can be fixed its only the price that varys i think you have a fault in the switching mech as the unit is 25yrs old they didnt use digital switching back then i think your unit has the old spring loaded power button the problem is that the small spring behind the latch comes loose after many years and needs to be set correctly so take it to a shop and see if they know about spring switch resetting to see if this is deffinitly the problem push the button in hard if the power comes on but goes of as you realease it theres ya fault
best of luck
please take the time to rank my reply
Dec 01, 2010 | Kenwood Audio Players & Recorders
Goodman gds80703 turns on and off intermittendly 3 light blinks
There will be a diagnostic code that will blink on the control board. Look thru the clear window at the control board after the unit does not light up. On the reverse of the front panel, you will find a wiring diagram and in that area there will be a diagnostic code table. Sounds like a bad gas valve.
Feb 15, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Inconsistant Switching of Alpine MRA-F350 Amp
try and unplug the audiovox unit and check if problems still exist. and what swithes on what unit are you talking about? this kind of sounds like a wiring problem.
Nov 21, 2008 | Alpine MRA-F350 Car Audio Amplifier
My cd player works intermittently
i dunno wot is happenin but the same thing is happenin 2 my cd player nd it reli annoyin! please sum1 help!!!
Aug 28, 2008 | JVC KD-SX980 CD Player
Frigidaire HV2736B Kitchen Hood Logo
189 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
