Question about Insignia Digital-to-Analog Converter for Analog TVs
Finds no channels
The converter didn't find any channels after scanning in manual and auto. I saw someone respond saying the The converter is for over the air signals only, but I'm not sure what that means. Plugging the cable from the wall to the tv does not work. Do I need bunny ears too? I didn't think that was necessary. Please help.
    President:
  • Insignia Master
  • 1,779 Answers
It is meant for Rabbit Ears or Outside Antenna Only.....
Posted on Jul 24, 2009
    President:
  • 2,992 Answers
The box is a converter to allow an older TV to be used with the new digital TV broadcasting that went into effect in June. It converts off-the-air DTV signals (that is, the broadcasts from local TV stations in your area that go from their antenna over the air) to a standard channel 3 or 4 so you can watch on an analog ("old-fashion") TV. The converter needs to be used with a suitable antenna (rabbit ears or rooftop) to pick up those broadcast signals.
A DTV converter does not work as a cable converter box. If the cable you're hooking up is providing cable service, you'll need the cable company's box to get the programming.
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
What does "please run auto channel scan " mean?
Auto channel scan finds the local channels available over the air so that when pressing up/down channel it only goes to those channels
Mar 17, 2015 | Konka K2098U TV
How do I stop it from running the auto scan
Once the unit finds the channels it will stop scanning.
Jan 13, 2015 | Apex Digital Apex LD4088 40 Class LCD HDTV...
The tv keeps saying run auto channel scan
I have run the auto scan many times and it never finds any channel. I found that you have to put it on the HDTV, PC, AUDIO channels in order to watch or connect anything on the TV. Try doing that.
Sep 13, 2013 | Proscan PLDED3273A 32" LED 720p HDTV with...
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
How can i get the system to work with my tv
if you have it connected with the HDMI cable to your tv, use the ARC on the receiver to hear audio out.
Jul 18, 2010 | Panasonic SCBT230 Theater System
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
PVS31170Si Trutech TV Is this digital?
I have this model. I believe it is digital because the auto channel select finds numerous (a few hundred) cable channels (I have Comcast cable in Houston, TX) at channel 69 and above, e.g., 77-324, etc. I believe that analog tuners won't do this.
Does anyone have a manual for this TV? I'll pay to have a copy made.
Jan 15, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Feb 21, 2008 | Toshiba D-VR650
Insignia Digital-to-Analog Converter for Analog TVs Logo
460 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
