Question about Refrigerators
GE refrigerator Model TFX20D Will not cool. Tested T-Stat, Defrost Timer and thermostat on coil. Still does not cool.
  • kap61150 Jul 24, 2009
    The compressor seems to be running, but is it running to cool? Where do I find and test the overload, relay and capacitor? The overload should be ok as I do have power to everthing except heat for defrost!
  • 10,865 Answers
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Jul 24, 2009
MODEL MFU20F3GU01 SEARL #WB80912832 UNIT WILL NOT DEFROST
Can only be tested cold and it should show resistant. or the defrost timer is not operating
Jan 25, 2016 | Refrigerators
There is ice forming on the evaporator coils of my GE Monogram refrigerator. This is the "all-refrigerator" model (ZIRS36NMDLH). There appear to be two 'thermodisc'. One thermodisc is...
Hi.
When the back of the freezer is icing up you need to test the defrost system, which is responsible for the problem . The evaporator coils freeze up because the defrost system is not working. this results in compressor and fan running most of the time and in reduced or no cooling, particularly in the fresh food section. The freezer may still be cooling.
Defrost system problems are quite a common issue with refrigerators. Coils freeze because of a defective defrost system. With coils frozen the condenser will go under stress and will loose efficiency. The result is the system not producing enough cold to refrigerate the fresh food section while the freezer section instead keeps working.
Try disconnecting power overnight. Allow the freezer to defrost with power off. If the fridge works after that you have a defective defrost system. In that case the problem may come back after a couple of days. To fix the problem the parts comprised in defrost system must be tested, so to find and replace the defective part.
The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter. Element and thermostat are faulty if they return Ohms infinity (the circuit is open) when reading impedance with a multimeter at the part's contact.
If thermostat and element are OK, the next part to be tested is the fan. Fan can be tested by simply checking that the motor is running when energized.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar with your model.
Here all parts and diagrams for your model.
You can also find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 22, 2011 | GE Refrigerators
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Re GE TFX26ZP sid by side fridge Evaporator coil keep ice on it
the defrost thermostat should be clamped onto the evap coils..defrost timer should be under fridge. If this is a newer model, it might have an ecm ( comp control) on top of the compressor..
Sep 21, 2009 | GE GSL22JFR Side by Side Refrigerator
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
GE Fridge not cooling well, frost in freezer,back wall and coils
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Refrigerators
GE Model TFX20D not cooling!
Hi, If the defrost heater doesn't come on, check continuity on the bi-metal swtch located on the top of the evaporator coil. The bi-metal needs to be cold when testing it. If the switch is cold and shows an open circuit, it will need replaced. The bi-metal switch is a thermostat that turns the defrost heaters off when the desired tempurature is reached,.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Jul 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model gss side by side refrigerator
I ASSUME YOUR TALKING ABOUT THE COILS BEHIND THE BACK OF THE FREEZER ..IF SO YOUR UNIT IS NOT GOING THROUGH THE DEFROST CYCLE BECAUSE OF A BAD HEATER OR BAD DEFROST TIMER OR BAD DEFROST T STAT .YOU CAN FORCE IT INTO DEFROST BY PUSHING THE FRESH FOOD DOOR SWITCH THREE TIMES IN 15 SECONDS IF YOU HAVE AN ADAPTIVE DEFROST TYPE OF DF CONTROL(ELECTRONIC TYPE).
Apr 02, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
379 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
