Question about KLH ASW12-120 Subwoofer
Klh asw12-200 sub goes on but i get on sound anymore
    Genius:
  • KLH Master
  • 1,550 Answers
The audio amplifier IC damaged replace him
Posted on Jul 24, 2009
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
My KLH powered sub maks e a humming sound when i plug it in but it only hums when the speaker is hooked up i tried others but did the same eventually speaker started smoking would wrong fuse do that
Wrap a wire around the outside Metal of your rca jack in back of your radio and ground the other end of that wire to the back of your radio and the noise goes away
May 09, 2015 | KLH Audio Players & Recorders
Klh powered sub woofer
Low level inputs are designed to take signals directly from an amplifier's "sub out" connections. That way the KLH amplifier will use those signals to produce sound and the volume can be balanced between the main amplifier and the sub amplifier using the sub's volume controls. Depending on your amplifier and sub, that is the best way to connect them. However, be careful running the RCA cables since the low levels are more subject to interference. Keep the runs as short as possible and use high quality shielded cables for the interconnects.
Aug 26, 2014 | Audio Players & Recorders
How to connect a subwoofer to a klh 5100
this unit has a sub output on the back to connect to a powered sub, or an amp/reciever and passive sub
Mar 09, 2013 | KLH R5100 Receiver
I'm about to hook up my KLH to an Onkyo Receiver with Audyssey sound features. 2 questions: it asks me to set my sub to 75 DB. Since my volume dial goes 0-10, which number maps to 75 DB? Also, what...
I think it wants you to raise the volume high enough on the sub so IT can hear at least 75dB. It can always adjust the sub downward if necessary. Max it out at the sub and let Audyssey deal with the adjustment.
Your crossover frequency selection would be a piont below which you want the sub to activate. It depends on the bass capabilities of your other speakers. You want some overlap so there's no droop in the crossover region where your main speakers roll off.
Jul 13, 2011 | KLH ASW10-120 Subwoofer
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
I have a klh home theater speakers with a subwoofer the sub work but when i hook up speakers no sound comes out?
The sub works but the speakers don't? Do you hook up the speakers to the subwoofer output "loop"? This is a circuit issue when it works and stops working. I have the same issue so I wound up joining the wires that go to the sub and the wires that go to the speaker together and place those connections into the sub. The sub works, the satellite speaker works and the impedance load is no issue for my system. Confused? Simply run your neg/pos wire to the sub and where it connects to the sub, run another cable to the speaker (pos to pos., neg to neg).
The only way to repair it would be to deal with component level repair. Although I have the experience, it is too petty and it works fine the way it is.
Apr 12, 2011 | KLH ASW10-120 Subwoofer
Klh subwoofer asw12 200 powers on but no sound, hooked up my other sub works fine
There's an amp inside the unit, most likely the semicondutor that does all the work has failed in it.
Jan 29, 2010 | KLH ASW12-120 Subwoofer
KLH R5100
in stero mold only 4 speeker will work ftr ftl center sub u need a sound sliter cornet it to the tow frount that what i did
Dec 01, 2007 | KLH R5100 Receiver
KLH ASW12-120 Subwoofer Logo
274 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
