Question about Acer Aspire 3680 Laptop
VISTA IS NOT PERFORMING RIGHT
I HAVE WINDOWS VISTA AND I WOULD LIKE TO SWITCH TO WINDOWS XP
  • Godfather22 Jun 19, 2008
    I have had vista for about a year now and i cant stand it anymore and i want to switch to xp but i dont know how.
I want to get rid of windows vista and install windows xp
I suggest to upgrade to Windows 7 instead of downgrading because Windows 7 has better performance than Vista. But if you still want to go to Windows XP you have 2 choices.
The first is to format the drive where Vista is installed and to install fresh copy of Windows XP.
Second choice is to install Windows XP as second OS and at the end of the installation, at activation step, you have to choose activation by Phone. Then you should call Microsoft Helpdesk and provide the code of your Windows XP to the operator and tell him that you need downgrading Vista code. Then he will guide you to the rest of the activation and the downgrade of Vista.
Oct 09, 2011 | Acer Aspire 5610-4648 Notebook
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
Tip
How to make your computer faster
1. Defragment your computer hard disk using free tools like SmartDefrag.
2. You should also defragment your Windows pagefile and registry.
3. Clean up hard drive disk space being taken up by temporary files, the recycle bin, hibernation and more. You can also use a tool like TreeSize to determine what is taking up space on your hard drive.
4. Load up Windows faster by using Startup Delayer, a free program that will speed up the boot time of Windows by delaying the startup of programs.
5. Speaking of startup programs, many of them are useless and can be turned off. Use the MSCONFIG utility to disable startup programs.
6. By default, the size of the paging file is controlled by Windows, which can cause defragmentation. Also, the paging file should be on a different hard drive or partition than the boot partition. Read here on the rules for best paging file performance.
7. In Windows XP and Vista, the Windows Search indexing service is turned on for all local hard drives. Turning off indexing is a simple way to increase performance.
8. If you don’t care about all the fancy visual effects in Windows, you can turn them off by going to Performance Options.
9. You can optimize the Windows boot time using a free program called Bootvis from Microsoft.
10. Clean your registry by removing broken shortcuts, missing shared DLLs, invalid paths, invalid installer references and more. Read about the 10 best and free registry cleaners.
11. One of the main reasons why PC’s are slow is because of spyware. There are many programs to remove spyware including Ad-Aware, Giant Antispyware, SUPERAntiSpyware, and more.
12. If you have a deeper spyware infection that is very hard to remove, you can use HijackThis to remove spyware.
13. Remove unwanted pre-installed software (aka junk software) from your new PC using PC Decrapifier.
14. Disable unnecessary Windows services, settings, and programs that slow down your computer.
15. Tweak Windows XP and tweak Windows Vista settings using free programs
16. Disable UAC (User Account Control) in Windows Vista
17. Tweak your mouse settings so that you can copy and paste faster, scroll faster, navigate quickly while browsing and more. Read here to learn how to tweak your mouse.
18. Delete temporary and unused files on your computer using a free program like CCleaner. It can also fix issues with your registry.
19. Delete your Internet browsing history, temporary Internet files, cookies to free up disk space.
20. Clean out the Windows prefetch folder to improve performance.
21. Disable the XP boot logo to speed up Windows boot time.
22. Reduce the number of fonts that your computer has to load up on startup.
23. Force Windows to unload DLLs from memory to free up RAM.
24. Run DOS programs in separate memory spaces for better performance.
25. Turn off system restore only if you regularly backup your Windows machine using third party software.
26. Move or change the location of your My Documents folder so that it is on a separate partition or hard drive.
27. Turn off default disk performance monitors on Windows XP to increase performance.
28. Speed up boot time by disabling unused ports on your Windows machine.
29. Use Process Lasso to speed up your computer by allowing it to make sure that no one process can completely overtake the CPU.
30. Make icons appear faster while browsing in My Computer by disabling search for network files and printers.
31. Speed up browsing of pictures and videos in Windows Vista by disabling the Vista thumbnails cache.
32. Edit the right-click context menu in Windows XP and Vista and remove unnecessary items to increase display speed.
33. Use the Windows Performance Toolkit and the trace logs to speed up Windows boot time.
34. Speed up your Internet browsing by using an external DNS server such as OpenDNS.
35. Improve Vista performance by using ReadyBoost, a new feature whereby Vista can use the free space on your USB drive as a caching mechanism.
36. If you have a slow Internet connection, you can browse web pages faster using a service called Finch, which converts it into simple text.
37. Use Vista Services Optimizer to disable unnecessary services in Vista safely.
38. Also, check out my list of web accelerators, which are programs that try to prefetch and cache the sites you are going to visit.
39. Speed up Mozilla Firefox by tweaking the configuration settings and by installing an add-on called FasterFox.
40. Learn how to build your own computer with the fastest parts and best hardware.
41. Use a program called TeraCopy to speed up file copying in Windows XP and Vista.
42. Disable automatic Last Access Timestamp to speed up Windows XP.
43. Speed up the Start Menu in Vista by hacking the MenuShowDelay key in the registry.
44. Increase the FileSystem memory cache in Vista to utilize a system with a large amount of RAM.
45. Install more RAM if you are running XP with less than 512 MB or Vista with less than 1 GB of RAM.
46. Shut down XP faster by reducing the wait time to kill hung applications.
47. Make sure that you have selected “Adjust for best performance” on the Performance tab in System Properties.
48. If you are reinstalling Windows, make sure that you partition your hard drives correctly to maximize performance.
49. Use Altiris software virtualization to install all of your programs into a virtual layer that does not affect the registry or system files.
50. Create and install virtual machines for free and install junk program, games, etc into the virtual machines instead of the host operating system. Check out Sun openxVM.
on Apr 06, 2010 | Computers & Internet
Unable to update or sychronize with time.windows.com
you need admin\administrator rights to change anything on vista. it is suppose to be more secured than Windows XP.
administrator /user is power user rights, which don't have rights to change system setting, but you do have rights to install certain program.
login into the machine as administrator and provide the corect password.
Apr 28, 2009 | Microsoft Windows XP Home Edition
Tip
How to speed up the performance of your Microsoft XP/Vista/7 computer with just...
The steps below offer a very fast and easy way to improve the performance of your XP/Vista and even windows 7 computer.
  1. Click Start, right-click Computer/My Computer(depending on OS), click Properties, and then click Advanced system settings.
    Collapse this imageExpand this imagesecurityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  2. On the Advanced tab, click Settings under Performance.
  3. On the Visual Effects tab, click Adjust for best performance, and then click OK.
  4. Click OK to close the System Properties dialog box.
This is a very quick way to improve performance with your system in just a few easy clicks. I recommend it to anyone and everyone.
Hope you all enjoy
-LeeTheDeuce
on Jan 20, 2010 | Computers & Internet
Xp & vista
you can install both into your computer, even into the same drive / partition, but its not recommended, in that case it is required to install into a diffrent named folder than c:\windows
I personally have 2 working xps installed incase the other gets messed up I don't have to spend a few hours reinstalling right then and there il just start up the other one.
http://www.google.com/search?q=multiboot+windows&rls=com.microsoft:fi&ie=UTF-8&oe=UTF-8&startIndex=&startPage=1
Oct 21, 2008 | Microsoft Windows Vista Home Premium with...
Cannot run Fujifilm Software for FinePix with Windows Vista
1) If you right-click on the executable file, can you use the
"Compatibility" TAB to run it as an XP program?
2) Many XP device drivers will fail to install or execute properly
under windows VISTA, and I suspect it is the camera's USB
or Fire-wire (IEEE-1394) based device driver that is causing
the problem, not the main application.
Unfortunately there is NO easy solution for this,
except to get an upgraded software package (for Vista)
from the Camera Manufacturer.
3) There are also two possible work-around(s), but both require
some knowledge and software installation:
DUAL-BOOT
Install both Windows XP and Windows Vista on your
computer using two separate hard-drive partitions, and
a boot manager.
A partitioning tool like "Norton Partition Magic", formerly
"Power Quest" or "Acronis Tools" can be used to partition
the hard-drive non-distructively (your data is preserved):
a) Resize (shrink) the existing Windows partition.
b) Create a new partition for Windows XP (about 10 Gigs)
c) Install Windows XP-Pro onto the new partition,
d) Add both the XP and Vista partitions to the BOOT.INI
file on the boot drive.
Both windows XP and Vista do have multi-boot capability,
but the Windows XP boot manager may not recognize Vista,
in which case you may have to re-install or re-pair the Vista
installation. The Vista boot manager will recognize WinXP.
Running VISTA is generally a bad idea, because it is obscenely
slow and inefficient compared to XP, and because it is infected
Microsof't draconian and arrogant copy protection schemes,
known as DRM = Digital Rights Management.
Towards this end, Vista also insists that all installed multi-media
devices must be "Recording Industry" compliant and approved,
to make music and movie piracy more difficult. Many media
copying programs and CD-rippers will also refuse to run,
by design.
All this "Added Technology" is stealing your money, your
computer resources, your performance, and your right to
backup your media, at your expense, for the benefit of
the movie industry Mafia.
Use Vista only when you have to, boot to Windows XP for
most of your applications.
VIRTUAL MACHINE
Both Microsoft and VM-ware (as well as others) make
a software product called a Virtual-PC, which allows you
to emulate multiple operating systems under windows,
including older windows, MAC and Linux.
VMWare is by far the best, the most reliable and the
most flexible, at about $200 US.
Martin
May 07, 2008 | Computers & Internet
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
Acer Aspire 3680 Laptop Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
