Question about Tilia Foodsaver V835 Vacuum Sealer
FoodSaver heat strip
The heat strip on my Foodsaver 835 suddenly stopped heating to make a seal. This is only a little over a year old and used sparingly
2 Suggested Answers
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
Foodsaver troubleshooting
The same thing happened to mine and I found a really,really inexpensive way to resolve it. I don't use original foodsaver bags and I found out that their thickness might not be detected correctly so it won't vacuum. To compensate for this, I used an ordinary piece of notebook paper. I cut it to a size of 4 1/2" by 1 1/2". I set the long side in the middle of the liquid catching tray and let it lean back towards the heat strip. Make sure it doesn't cover the heat strip or it won't seal. Now I inserted the bag as the directions say, close and lock the top, and it vacuums and seals perfectly. b40a3e78-1fd3-4c38-9291-c5c4e3885648.jpg
Jan 05, 2014 | Kitchen Appliances - Others
Vacum works heatseal does not seal can i replace seal
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver vac800 not sealing bags any way to fix heat strip?
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Sep 16, 2010 | Tilia Foodsaver V835 Vacuum Sealer
I have a foodsaver and it sucks the air out but won't seal. What do I do? We're trying to save some frozen fish and it just sucks and sucks but doesn't stop or seal. Any ideas?
The bag is wrinkled or the gaskets are leaky, it has to pull down to a set vacuum in order to shut off and heat the strip to seal the bag. For the right now dilemma try pressing down on the lid while it's vacuuming and start looking for gaskets at foodsaver.com
May 29, 2010 | Tilia FoodSaver V2240
Dolphin Dive Center
May 17, 2010 | Tilia FoodSaver V2240
My food saverf V 835 just stopped sealing. I haven't used it that much, and it worked fine last time I used it.
I just spoke to customer service. I was told there is no replacement part for the heating element. They did offer me a discount on a new Foodsaver.
Feb 21, 2010 | Tilia Foodsaver V835 Vacuum Sealer
My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Aug 22, 2009 | Tilia Foodsaver V835 Vacuum Sealer
What is a heat seal I see one on ebay but say it needs heat seal what are they talking about were can i get one or some for thev3825 foodsaver
the function that seals the bag after the vaccum process (melts the plastic to itself) Hope this helps
Jul 13, 2009 | Tilia FoodSaver V2240
Foodsaver compact vac 550 sealing strip doesn't seal
My machine stopped working because the sealing ribbon was broken and the tape was worn. FoodSaver no longer does repairs. I knew the wire was called nichcome ribbon so I searched that. I checked the resistance of the ribbon on my machine, it was about 3.8 ohms. I found a site called mpakonline.com and from their site I bought 1/16 x .005 nichrome ribbon and 3/8 x 5 MIL. x 18 YD Acrylic Teflon Tape. The total cost of these items was about $36.00, the ohm value of their ribbon was 1.66 somewhat less.I used ends from radio shack made the repair and it has been working fine for the last two months and I have enough material leftover for about ten more repairs.
Nov 14, 2008 | Heating & Cooling
Tilia Foodsaver V835 Vacuum Sealer Logo
490 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
