Dell Axim X51v Pocket PC Logo
Posted on Jul 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot connect to the internet
Even when i turn WLAN on it doesnt connect
Anonymous
Level 2:
  • Expert 64 Answers
  • Posted on Jul 24, 2009
Anonymous
Expert
Level 2:
Answers
64
Questions
0
Helped
21899
Points
153
On scan does it see it
1helpful
Atheros AR5007EG can't connect via WPA2 to WLAN on Windows XP
WPA2 is considered insecure and hacked years ago.
You might try WPA, or get a different Adapter.
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
I cant get wlan connection.. I have run windows 7 now many times.. Even if i press buttons Fn+F1 it doesnt work.. What can i do?
Did you upgrade your laptop or pc to Windows 7? If you did you may need a driver for your WLAN that is compatible with windows 7. Check you windows 7 if it is a 64 bit or a 32 bit because you have to download the appropriate drivers. If you are using the default windows version, check device manager to check if your WLAN is working or installed.
Does not connect to a wifi network even in a full network and connect with a limited connectivity.
determine if the network is working correctly by using another wifi device and logging on
then check to see if you entered the password correctly
try resetting the router by either resetting it with the reset button in the back and a paperclip or by unplugging and shutting it off
if those dont work try using the windows network repair utility
if the wlan connection still doesnt work contact your internet service provider
good luck
have a nice day post nice things
4helpful
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
My hp pavilion entertainment pc is showing orange for the wireless connection.. when I click on it, it doesn't turn blue it just says WLAN: on or WLAN: disabled but even when it says its on it stays orange...
1. Go to device manager ad check your wireless card is not diabled,
2. Try to search your network and see if your laptop could detect it
3. you can try Fn + f2 kesy as well to turn off/on your wireless switch,
6helpful
2answers
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
I TRY TO US THE USB PORT TO CONNECT MY PSP TO THE INTERNET AND IT SAYS THAT THE WLAN SWITCH IS NOT TURNED ON.PLEASE HELP.
The usb is only used for file transfer,WLAN is a wireless connection,you are going to need a wireless box,then you can connect your psp via WLAN to the internet to download stuff....
Thanks for your question,
have a nice day!
How do i turn on the WLAN wireless internet button
You have the highspeed internet connection and turn on the modem first then the Wlan internet button will automatically on. If you are using the dial-up connection ,firts dial into the internet connection and connect and wireless interntet will on.
try it and inform to fixya.com
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
