SOURCE: I need a manual
The model number should be posted on a nameplate near the oven door opening and/or lower drawer opening (if equipped). Sometimes the model number is located along the back of the operator console. You will need this model number in order to ensure you are getting the correct manual as all appliances are not the same with operation and features. Go to geappliances.com and click on the "Service and Support" link. On the next page is a heading for "Use and Care Manuals". Click on the link, type in your model number, and there should be a manual available for you to download in .pdf format (Adobe). I hope this helps you.
SOURCE: Frigidaire PLES389DCC MODEL Electrolux
318223626 -
MAIN TOP
found it listed from 230.68 at prosupplyco.com
up to 281.85 at Repairclinic.com
hope this helps,
best of luck,
ttfn
SOURCE: Frigidaire Gallery Range m#FEF389CFBK. The heat
Hi, If I was being called out to look at your range and you described to me what you said in your post, I would definetly bring an element. I suugest you tell that to your service person or purchase a new element. That is quite often the way the element's burn out, just as you described...a sparkler. Hope that help's. Good luck and thank's for visiting fixya. Macmarkus :)
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
