Question about Dynex 19 in. LCD Flat-Panel HDTV
Powers on then immediately off
Dynex 20" DVD/TV Combo, less than two years old
I insert a DVD into my Dynex 20" TV DVD combo, Display says loading, I can hear the disk spinning around, and then display will say no disk
Ur DVD disk,scratches that might effect it or it dirty like fingers prints or dirts and grims to the laser surface.Clean it with some dish washing soap.
Sep 27, 2009 | Dynex 20" TV/DVD Combo
I have the Toshiba TV/DVD Combo less than 3 years old
check thje following
the power reaching your switch via a fuse and power out of the switch, when switched on.
if the power is leaving the switch okay then check the power supply components
semi conductors, for leaks and shoots, zener diodes, and capacitors for variations and change of values especially electrolitic capaciturs. if you get a high voltage of 85 and above going to the transistor near the transformer, then check your line trasistor.
Aug 18, 2009 | Toshiba MD20F51 20 in. TV/DVD Combo
No picture, can't set inputs on TV
try tighting the screws on the inverter. they sometimes get loose and then you lose the grounding.
Apr 20, 2009 | Televison & Video
Old TV and old DVD player
Make sure your TV is "tuned" to the proper input. To change the input, change the TVs channel below 02, find the "input" dialoge on the tv's menu, or press the "input" or "video" button on the TV or Remote.
Repairing a 20 year old VCR (By chance a BetaMax?) is not worth your time. Replace it with a $60 DVD/VHS combo unit.
Mar 12, 2009 | Televison & Video
20 inch Symphonic TV/DVD Combo fuse keeps blowing immediately.
hello it sounds like theres a dead short unless you have a multimeter and oscilloscope a diagram and a bit of know how then yes you could do it youself i'd would get a quote for a repair good luck
shaun
Jan 17, 2009 | Symphonic SC519DD 19 in. TV/DVD Combo
Problems with the tv coming on
It seems like there's a problem with a component on the Power Supply of your TV or there's a problem with your Picture Tube. I don't recommend you working on TV's unless you know what you're doing since you can get badly shocked if you don't discharge the Ulter Cap on the Picture Tube. If you don't know what you're doing then I suggest you get it repaired by someone who knows what they're doing.
Apr 21, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Tv\DVD Wont turn on
Quizas el sistema de la vcr este fuera de tiempo,por causa de la banda del motor de carga el aparato tiene que ser abierto para ser reparado llevalo a un taller.
Mar 28, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
Toshiba TV/DVD combo turns on then off again.
try letting it sit for 15-20 minutes unplugged from the wall and maybe try another outlet depending on if u got plugged in to a power strip, possibly pulling to much power from that perticular outlet.
Oct 16, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Dynex 19 in. LCD Flat-Panel HDTV Logo
158 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
