Question about LG LRSPC2031 Side by Side Refrigerator
Water dispenser not working
The water dispenser stopped working. There is a click sound (from a relay?) when using the dispenser. The ice maker seems to be working and making new ice. Is there a separate pump for the water dispenser that may have broken? Any suggestions?
  • beden Jul 15, 2008
    LG refrigerator water dispenser not working. Ice maker is still working. I put in a new filter but still not working
  • Anonymous Mar 26, 2014
    I get very little water for a couple of seconds then nothing
  • 489 Answers
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Posted on Apr 27, 2008
    Problem Solver:
  • 13 Answers
There is a separate path for the water dispenser line. It's possible that the water solenoid is broken, but much more likely is that the water dispenser line is leaking. Take a good look, because it could be leaking onto your floor.
On the refrigerator side, if you take out the fruit and vegetable bins, you'll see a sort of serpentine water reservoir. This is where water is chilled. Unscrew the tubing from one side and run the water dispenser. If water does not gush out of the line, then the line must have burst somewhere. A likely place would be the place where the tubing goes by the compressor, as that receives a lot of heat cycling. If you unscrew the tubing at both ends, you'll find that it can be pulled out easily, as it's in a conduit that guides it. Replacement tubing can be purchased by the foot at larger hardware stores.
Posted on Nov 06, 2011
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Clicking sound from back of fridge
Its faulty capacitor or compressor relay or the timer.Its in the lower end back.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Hotpoint HSS25GFP Side by Side...
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
My Samsung RS2556BB refrigerator ice maker is not making ice anymore. The freezer still very cold but there is no water coming into the ice tray. I switched the relay in the back and pressed the water...
These will help.
Thanks,.
Dec 22, 2012 | Samsung RS2556 Side by Side Refrigerator
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
These will help.
Thanks,.
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice Dispenser on Kitchen Aid Model KSCS25FTBL has stopped working
It can be faulty ice maker assembly and needs to be replaced.
Sometimes it visually sees ok,but actually its worn out or cracked causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Water dispenser & ice dispenser stopped working
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
The water line is clogged or water dispenser valve is blocked.Click this link below for troubleshooting:---
This will help. Thanks. Helpmech.
Oct 31, 2011 | Refrigerators
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
Sep 18, 2011 | Refrigerators
LG LRSPC2031 Side by Side Refrigerator Logo
4,095 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
