Question about Dell Inspiron 5100 Notebook
Computer will not turn on. power supply is ok. when on botton is pushed for the first time battery led flashes 10 times and stops. fan does not go on. 2nd time the power button is pressed, the battery led stays on for 10 seconds and turns off, still no fan
    Problem Solver:
  • 6 Answers
Hmmmm, I'm thinking DUST has clogged your fan and the CPU is overheating and shutting down your computer. Find a way to blow some air through the vents in the case. This may loosen up any dust and if your lucky it'll blow out. Only other thing I can think of is to open the case and take a look.... if you are confident enough. If not don't.
Posted on Jul 24, 2009
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
This should work....all the best
May 19, 2010 | Computers & Internet
It terns on on then it sayes protect
1 suspect speakers or speaker wiring, remove all speaker and replace one at a time to check they are sound.
2 suspect dust in the fan in the back, if the fan stops on the power supply this may cause protection to cut in.
3 First power off and push the "stop" botton more than 10 seconds at right side main player.
this may clear fault.
this seems to be a common problem and the vendor are not forthcoming with solutions, blogs are recommending steering clear of this model.
Nov 13, 2009 | Samsung HT-DB600 System
When i press power buton computers, on/off led just blinks once,cpu fan turn few times and stop, power supply fan also turn few times and stop and computer does not start.
Possible bad power supply, hard drive, and or CPU. If there is a computer repair store close to you, I would take the hard drive to them and have it checked out thoroughly to make sure all the sectors are in tact and possibly have the power supply OHM'd to make sure the proper amount of voltage is coming out in order to turn the computer on in the first place.
Oct 11, 2009 | LG L1915S 19" LCD Monitor
Hipro HP-d3057f3r computer power supply broken?
I have the same problem. I found this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph06788&product=12455#bph06788_section_2
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
  • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
  • Aug 16, 2009 | Hi-Pro Computers & Internet
    Dell inspiron 2200 green LED battery Indicator flashing
    sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
    Jun 21, 2009 | Dell Inspiron 6000 Notebook
    Booting problem
    DEAR,
    AS PER YOUR PROBLEM I THINK YOUR COMPUTER WORKING WITHOUT ELECTRIC EARTHING. PL FIRST COMPLETE EARTHING WITH ELECTRICIAN.
    YOUR EARTHING IS NOT PROPERLY PL CHECK THAT:-- ELECTRIC SHOK ON PC BODY.
    YOUR PROBLEM WITH POWER SUPPLY OR PROCESSOR,MOTHERBOARD.
    PL FIRST CHECK POWER SUPPLY,SECOND CHECK YOUR PROCESSOR WITH ANOTHER PC MOTHERBOARD.
    Feb 25, 2009 | Acer Aspire™ T180 PC Desktop
    Psu shut down
    99% TIME IT IS A FAULTY FAN GOING OUT.
    REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
    P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
    CANDYMANGANDY
    Jan 27, 2009 | Antec Solution SL400 Power Supply
    Power up problem
    Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
    Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
    Dell Inspiron 5100 Notebook Logo
    201 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
