Question about Motorola Mobility RAZR2 V8 Cellular Phone
How can i bring back orange menu icons
I had my orange phone unlocked and so the menu icons have changed but i still want the original orange menu icons so what can be done to change them back?
Would like to get LG G FLEX LS-995 from SPRINT unlocked can anyone help
I got this off of google. hope this works for you.
How to Enter Unlock Codes on LG KE990 / KU990 Viewty:
  1. Insert original sim card and turn phone on.
  2. Press telephone icon at bottom of screen to bring up the phone keypad.
  3. Enter 2945#*990#
  4. A menu will pop up, select sim unlock:
  5. Another menu will appear, select Network lock.
  6. Enter your unlock code and press ok.
Dec 25, 2014 | Cell Phones
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Unlock my lg u990
You can Unlock it simple by using the Unlock Code ,you can get the Unlock code at low cost from here
Superunlockcodes and follow the instructions below and UNLOCK IT.
LG U990 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG U990 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG U990 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your LG U990 with its ORIGINAL SIM Card.
2. Press the telephone icon at bottom of screen to bring up the LG U990 keypad.
3. Enter 2945#*990#.
4. A menu will pop up, select sim unlock.
5. Enter your Unlock Code and press ok.
6. The LG U990 will then reboot and the unlock is complete.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the LG U990.
(or)
1. Switch ON your LG U990 Without any SIM card.
2. Hold "camera" + "lock" button.
4. Enter your Unlock Code.
5. The LG U990 will then reboot and the unlock is complete.
Each LG U990 mobile phone has an unique unlock code. You can buy the unique unlock code for your LG U990 mobile phone using the form above.
Jul 13, 2011 | LG Cell Phones
My lg ke 990 it doesn't work with sim card sir . please helpe me too.
Model : LG KU990 Viewty & KE990
1. insert original sim card and turn phone on.
3. Enter 2945#*990#
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Jun 20, 2011 | LG KU990 Viewty
I lost the password to my phone and i cant remember it i cant unlock it anymore and i need help unlocking it
3. Enter 2945#*990#
ku990 support 2g sim after unlock??
Apr 01, 2010 | LG KU990 Viewty
I programmed m phone in mex with telcel co. and want to use it in calif. with my t mobile sim card but it asks for a restriction code.....
you have to unlock it 1. insert original sim card and turn phone on.
3. Enter 2945#*990#
hope this helps
Jan 05, 2010 | LG KU990 Viewty
Need unlock code for Lg Ku990 Viewty phone
I understand that you need an unlock code for your LG KU990 Viewty Phone.
1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok6. The phone will then reboot and the unlock is complete.
Dec 22, 2009 | LG KU990 Viewty
LG U990 USIM locked
3. Enter 2945#*990#
Try this, this may solve your problem.
Aug 16, 2009 | Audiovox SMT5600 Smartphone
K810i, how to change menu icons
go here you will find a soulotion
http://answers.yahoo.com/question/index?qid=20080830163042AAtcIRC
Jul 24, 2009 | Sony Ericsson K810i Blue Smartphone
Unlock codes...
  • Mail to orange (UK) network requesting for the unlock code(for more information how to get the unlock code contact your service provider).After receving the code follow the below steps
1) In main menu select the Manage connections icon & turn all connections off
2) Select the option icon in the main menu then select the Advanced option
3) Scroll down and select Simcard
4) First type MEPD, select the network as Yes then type MEP2 (it will not be visible) and then type the Unlock code
5) Press Enter to finish.
After doing all the above steps with out switching off the handset remove the batery and sim after few seconds reinsert them again.
Dec 27, 2008 | RIM BlackBerry Pearl 8120 Cellular Phone
Motorola Mobility RAZR2 V8 Cellular Phone Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
