Question about Garden
Try to start starts with starting fluid but itsx
Try to start starts with starting fluid and it starts then dies but it doesnt appear to be getting any fuel.
  • 850 Answers
Check if pump is working
Posted on Jul 24, 2009
My cobalt cranks but won't start
sometimes engines can crank but just cant crank fast enough to start. try jump starting it. if that doesnt work try unplugging the mass airflow sensor and starting it. if that works could be a bad mass air flow sensor. if that doesnt work (if you are mechanically inclined enough) try spraying a little starting fluid or flammable break clean into the throttle body and try to start it to see if it starts and then dies. if this is the case then you have a fuel issue (most likely the fuel pump). if this doesnt work you'll need to get a code scanner to see if there are any codes. if there are try to figure out the ones that seem like they are related to the engine running (aka crank sensor, coil circuits, or lean and rich codes ect.) usually in this instance you'll have to take it to a shop to figure it out
Nov 29, 2015 | 2008 Chevrolet Cobalt
1999 Dodge 1 ton won't start sometimes. There's no set pattern to it. Sometimes it'll crank right up, but other times ill have to try it everyday for a week before it'll start.
when it doesnt start does it crank? if it cranks all day and doesnt start spray some starting fluid in the throttle body and see if it starts and then if it dies then you are not getting enough fuel pressure but if it doesnt start then your iginiton system is acting up or your crankshaft sensor could be bad
Sep 13, 2013 | Dodge Ram Cars & Trucks
My 2001 caravan overheated sputtered then died. wont start. tries to start but wont.
Sounds like you might have clasped the rings and you have no conpestion do a conpestion test on it
Mar 03, 2013 | 2001 Dodge Caravan
Doesnt start. has fuel pumping and is getting fire to the plugs
I had the same starting problem and after it would start at all had all the new stuff fuel pump,tune up, i even start flushing the transmisson fluid anyway i spent a tone of money with a lot of machnics who were stumped.......try the idel control switch mine over heated witch happends all the time in the hot weather only 38 bucks about hope it helps
Nov 24, 2011 | 1994 Buick Skylark
My 1999 durango wont start but turns over
This sounds like it doesnt have spark or fuel. i have repaired a few of these durangos for nostarts. the first thing to do is to find out if its lacking spark or fuel. get some starting fluid spray and have someone hold the gas pedal down and spray it into the throtlebody then have them release the pedal and try to start the truck, if it starts and then dies out after the fluid is bruned then you have a fuell problem, the most common reason for fuel problems is the fuelpump in the gas tank goes bad. another test you can do before the starting fluid is to have someone trying to start the truck while you beat on the bottom of the tank with a rubber hammer. this must be done while the engine is cranking over, if it starts then the pump in the tank is bad. if truck doesnt start with the fluid or beating the tank then check it for spark. you will need to remove a sparkplug wire and place it near the engine to allow the spark to jump to ground, you may need to insert a screwdriver into the plug boot and place near ground (engine) and see if you get spark while starting the engine, let me know the results and we will go from there. good day.
Oct 17, 2011 | 1999 Dodge Durango
Car runs for ten min then dies
Not sure what kind of car this is or year and etc, you will need to get the car to die and start with a couple of tests to see whats not working. next time it doesnt start, try spraying starting fluid into throtle and see if it starts and dies, if it does then we know its a fuel problem and may be fuelpump. if that doesnt make it start then remove a spark plug wire and place it near a metal object like the motor or a bracket and have someone try to start it and watch for sparks, if theres no spark then you may want to have the control module tested or the coil, hope this is helpful,
Nov 04, 2010 | Mercury Tracer Cars & Trucks
Truck will start first thing in the morning run about 2 min then die, and will not re start. till next morning has plenty of gas and have replaced ignition switch already, after doing this ran great for a...
you must make sure the fuel is getting to motor, check the fuel preasure after it dies check preasure or try spraying starting fluid in throtlebody to see if it a fuel problem, if it doesnt start then check for spark at the plugs,the most common problems are fuelpumps or control modules going bad,
Jun 09, 2010 | 1986 Chevrolet S-10 Blazer
02 caviler.. cranks but will not start.. have replaced crank sensor,fuel relay sensor.ignition module as well as spark plug module... and replaced battery
Squirt starting fluid in intake and try to start if it starts and then dies you have a fuel delivery problem. Make sure you check the fuses for a blown fuse namely fuel pump or fuelpump relay. If it doesnt start after squirting starting fluid in the intake check for spark at the plug wires and coil.
Dec 02, 2009 | 2002 Chevrolet Cavalier Coupe
I get power, not the battery or starter. but the truck won't start
I will try to help you with this its either going to be a fuel delivery problem or electrical. Take and squirt some starting fluid into the intake and try to start it if it starts then dies its a fuel delivery problem if it doesnt start at all check for spark at the plug wires then at the coil. Let me know how its going i will give you more info.
Dec 02, 2009 | 2004 Chevrolet Silverado 2500HD
Non starting echo strimmer SRM250E
spray some starting fluid inthe intake or drop in a teaspoon of gas. then try to start it . if it fires then dies it is not getting fuel if it doesnt fire it is something else. let me know the results so i can help further
Apr 11, 2009 | Echo Garden
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
