SOURCE: Wurlitzer 200a electric piano replacement transistors
I have cross-referenced most of the Wurlitzer 200A transistors to off-the-shelf replacement types. You can find the list at http://www.bustedgear.com/res_Wurlitzer_200A_transistors.html
SOURCE: I have a Wurlitzer piano serial #945466 how old
Definitely try this site:http://www.vintagevibe.com/t-wurlitzerabout.aspx Contact them. If this helped please rate me.
SOURCE: wurlitzer electric organ model 630 TA serial
Kontakt:[email protected] they have all parts on stock as well service manuals, this model is very unique it has an value!not a money value, keep it in shape... I owne an 625ta white, it sounds better as the 950 and also better as the 625 spinet model, i don't know why...Jimmy Smith UK recorded an superb Lp"tommorows sound today"
SOURCE: What is the age of my Wurlitzer piano serial number 192157?
Free Piano Age Research Look here. It looks like it was built between 1939 and 1940. Go down the page til you find Wurlitzer; after 1937: The year built is found by finding the serial number 192157, which would be between 180000 and 195000. That would make it having been built between 1939 and 1940. Hopefully, that's correct.
SOURCE: how do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Best of Luck
