Question about LG 32LG30 32 in. LCD HDTV
Can't get TV to display laptop screen
I have a Dell Latitude D600 connected to a 30LG32 HDTV via a VGA 15 pin cable. The tv has a plug and play feature that allowed me to initially watch a movie on the tv from the hulu.tv website without touching anything - what was on my laptop display showed up on the tv right away (and my laptop screen simultaneously) once I selected the RGB-PC option on the tv input menu. However, now I cannot get it to work this way again despite changing resolutions on both TV and laptop display. The lowest res the TV recognizes according to its menu is 1024x768, but LG (manual and cust svc) says it supports lower res through 600x800. The tv will display the boot up screen, which I understand to be 600x800, and a cropped pic of the desktop setting (w/o icons), but nothing else. On the mid-range res tv options (1260x768 and 1300x768) I get "invalid format" floating across screen, otherwise it's the "no signal" floater.
Thinking it might be a driver or video card issue, I took my laptop to PC outlet and had a tech look at it and hook it up to a larger LCD panel (they had no large LCD HDTVs) and it worked fine, allowing both displays to show the same thing simultaneously, even after the tech used the F8 key.
The LG tech was here earlier with a larger Panasonic laptop (I saw it had a default res of 1360xsomething-other-than-768), which of course was recognized by the TV and his laptop screen showed up fine, on both screens. When we scrolled through the tv res' via the RGB-PC menu, the correct res was flagged. Then we switched to cable to my laptop and the res on the TV stayed the same, even though we re-booted my laptop a couple of times. The LG tech used the F8 key and at first we were able to see both screens, although I understood that key was actually used to switch the destination of the video signals, so did n't see the need since images were showing up on both screens (TV and laptop). I left the room because I had to let the furniture delivery guys into the apt complex using a gate code, and when I returned, he said that he "turned it off and on three times and it seemed to be working okay, but just remember to use the F8 key". I said okay and signed off on the work order since the furniture guys needed me to sign off on their paperwork, too.
Once everyone left and I hooked the VGA cable back onto my laptop, I could only get a picture on the TV screen if I used the F8 key to switch over the video signal from the laptop display. Not the way I really wanted it to work, but acceptable. I placed an online Office Depot order this way, then I switched the TV input to watch a show. Now again I cannot get anything to show up from my laptop on the TV, even using the F8 key. It switches the signal away from my laptop, but it never shows up on the TV.
I just bought this TV in June and have been troubleshooting this issue for going on 3 weeks. It was a display model at a furniture store and they have no tech support to speak of and of course will not let me return it. However, it is under manufacturer's warranty. Previously, I exchanged cables, tried an S-video cord, and synchronized every res possible between laptop and TV, besides having the video card checked on my laptop. If you know of ANYTHING else I can try, please suggest it. If not, let me know if you think it is the TV or my laptop based on what I have written here. In the meantime, I called LG to send their tech back because I feel I should be able to use the plug and play feature as it is advertised without having to adjust settings on anything -although at this point I really wouldn't care, as long as I could just get it to work in this way.
Can I connect my dell latitude d600 laptop to my tv?
The Dell Latitude D600 has a VGA out. If your TV has a VGA connector then you should be able to connect it to it. All you have to do is connect the cable, and press the hot key to enable VGA output. Usually its Fn+F5 or Fn+F7 for Dell laptops.
Jul 06, 2011 | Dell Latitude D600 Notebook
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
HOW I CONNECT MY LAPTOP WITH TV LAPTOP MODEL IS DEL LATITUDE D600
all you need is a connecting cable depending on your laptop's tv out port. The following website displays several connecting cables. http://www.cableuniverse.co.uk/catalog/cable/pc-to-tv-cables/ Also, update your bios and graphic drivers
Nov 07, 2009 | Dell Latitude D600 Notebook
Connect Dell Latitude D600 to TV
try holding down the fn button and pressing at the same time the button with a small screen on it will do monitor switching
Aug 06, 2009 | Dell Latitude D600 Notebook
Can I connect my dell latitude d360 laptop to my tv?
When you connect the VGA cable to the TV you will need to hit the FN button + F5 on your keyboard, that will change the dispalys from internal to external. if you hit FN+F5 again you can have both the laptop and the TV screen on.
May 31, 2009 | Dell Latitude D600 Notebook
I have a Dell latitude D600 laptop
The D600 has no TV out option, the only Output for visual display is the monitor VGA port.
You would need a converter for the normal VGA to DVI Cable.
Mar 22, 2009 | Dell Latitude D600 Notebook
How do I connect my laptop to my tv
Right click on desktop. Select display properties tab, select the Extend windows desktop checkbox then click apply.
Jan 31, 2009 | Dell Latitude D600 Notebook
you need to have the same connections on both my laptop has svideo or vga connector, some have Hdmi which is the newest, but the tv and laptop have to bot have the same connectors, it may be a dvi, or any that I mentioned, then you need a cable for your video, and another for your audio, both the audio and video cables are run to the tv, the only one that has both audio and video is the HDMI which tv's from the last hear or 2 usually do have. Then depending which input the laptop is using which it will tell you where the connection for the tv is, you set it to that input and that turns your tv into a giant monitor
Dec 22, 2008 | Dell Latitude D600 Notebook
Conection to TV using S-video on Dell D600
Google this and read the forums... d600 s-video out
Dec 10, 2008 | Dell Latitude D600 Notebook
Acer notebook VGA problem
Not sure about your model as the header is Dell D600 and you mention Acer but the solution is probably the same. You need to enable the 2nd display - I'm assuming you are running XP. Go to display settings -easiest way is to Right click on the desktop, bringing the display menu and Left click on Properties (bottom entry). Then click on Settings and you should see 2 screens and you will need to enable the 2nd monitor and set up how to display on it. Additionally there is a setting in the BIOS that enables both display outputs.
Feb 19, 2008 | Dell Latitude D600 Notebook
LG 32LG30 32 in. LCD HDTV Logo
1,630 people viewed this question
Computer Repairing
Computer Repairing
