Question about Compaq Presario 700 470024-192 Notebook
Dvd drive does not operate at all no power to it
  • 2,418 Answers
Ck in the control panel, device manager see if it show up. Uninstall it shut down reboot reinstall.
Posted on Jul 24, 2009
Wont start
ok try the following in order
1 make sure power adapter is plugged into a socket which is turned on and delivering power
2 with power adapter plugged into laptop are any lights showing, you should have at least a battery light showing if the power adapter is delivering power
3 when n you turn on your on button press f8 and see if you are returned the bios setup page, if you are then your motherboard is at least reading the bios if not you may have a motherboard issue
4.from a different computer search for knoppix and burn to a cd/dvd which ever your laptop has
5. put the newly burnt knoppix disc in your cd/dvd drive tray and close tray and start system again.
6. knoppix will run as an operating system directly from cd/dvd. and allow you to check if your hard drive can be seen at least, if not then you may have an issue with your hard drive or the motherboard to hard drive interface.
if you can see your hartd drive it is likely your operating system might be corrupt or problems with disc, but you will at least be able to take files from hard drive to a usb stick and then reload operating system and have your data
hope it helps
Mar 15, 2015 | Computers & Internet
Dell desktop does not start booting when powered up. Fans and drives have power. Boot drive has been checked and is operating properly. Any suggestions??
Try to boot from a CD/DVD disc. Don't know how you can check your boot drive to see if it's O.K. though? If the computer boots from a CD/DVD disc then your OS (operating system software ) is corrupt and needs to be reloaded. That by the way is located on your boot (hard disk ) drive.
Jun 28, 2012 | Dell Computers & Internet
Toshiba satellite l300 wont boot from cd(internal and external)
Hi, Try to set-up your bios setting need first boot cd/dvd drive.Power on your PC, then press F2 to go bios setting, change first to CD/DVD drive first boot and then insert your cd or dvd operating system.if same problem. try also yung USB external cd or DVD drive.
Jan 26, 2012 | Computers & Internet
I turn on my Asus N50V and it hangs at the initial ASUS splashscreen ... if I hit F2 to entr the BIOS it goes through basic post but then hangs on the BIOS "Wait..." screen
Please remove any external devices (if connected) to your laptop
Remove the power adapter cable
Remove the battery
Push and hold the power button for 10 seconds, this will remove unwanted charge from the laptop electronics.
Then connect the power adapter cable alone and switch the laptop on and check if it is working fine.
If not remove the power adapter and connect the battery alone and try if it works fine. If it still does not then we have to remove the other components that are detachable from the laptop like
1. CD / DVD drive
2. Hard drive
3. Memory modules (if you have 2 remove one)
4. PC cards
even after checking with all the above options, if the computer is freezing we can definitely confirm a core hardware issue.
Feb 02, 2011 | ASUS N50Vn Notebook
Toshiba cd-rw/dvd-rom drive...power on but disc door will not actvate and open
There are quite a few reasons the DVD tray in your laptop might fail to open when you hit the eject button. About the worst thing it can be is if the motor or gear train failed, which would mean replacing the drive. If the disc in the drive plays OK, you know that the power and the connector are fine. If not, you should try reseating the drive in the bay. It's also possible for the drive to be locked in software by the operating system, or for a power management scheme to have cut power to the drive. Check these by right clicking the drive icon and checking properties, or looking at you power management settings. But, when all else fails and you can't get the disc out of the drive, there's always, THE MIGHTY PAPERCLIP.
Follow the bellow link,
http://www.fonerbooks.com/laptop12.htm
Hope this helps,
Jan 11, 2011 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
NEED TO DOWNLOAD DRIVER
1) there are no drivers....your operating system has whats needed to operate it.
2) hooking it to a netbook will require you to have it put in an encloser that has a power source, as you can not run the drive with out power supply.
3) you would be better off buying an external DVD Burner, One designed for your purpose. That unit you have will not operate on its own, and you can not hook it directly to your netbook
Dec 12, 2009 | LG GH22LS50 DVD-RAM Burner
Power Callibration Error
This error has nothing to do with your DVD drive hardware, so you can be sure your Laptop is ok. This is software error with Nero. Try and reinstall Nero or just try and burn DVDs at lower speed.
May 27, 2009 | Lenovo 3000 Y410 Notebook
Not operating
Check power supply capacitors.
Check capacitors for leakage or swelling.
Check voltages on drives +5 and +12
I can't tell you whether hard drive is faulty or not.
Apr 07, 2008 | JVC DR-MH30S DVD Recorder
Cd driver
you do not need a driver cd for installing the driver for cd/dvd drive if you are using windows xp or any of its higher version as all the hardwares are auto detectable in these operating systems....go to device manager and scan for hardware changes
Dec 29, 2007 | LG Electronics 16x DVD and 48x CD-ROM...
I need help getting dvd+rw drive operating
hi
go to nearer computer sales and support centre purchase a DVD R/W and if u have CD drive dis connect power cable and data cable then remove screws from cd drive then remove it fromyour cpu cabinate in same place insert your DVD R/W fix all screws,data cable and power cable.then connect all the data/power in backside of cpu if you r removed before otherwise again check all the cables and power on your cpu/moniter.after booting sucessfully your computer insert your nero cd which is given with your DVD R/W,cd automatically open then setup it one by one by soing instructions.after setup complete your DVD R/W is ready to read write CD/DVD.
thanks
Nov 12, 2007 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
