Question about Sony NWZ-E436F MP3 Player
Is there any hope, that having gone through the washer and dryer, that this will work again? It will hold a charge and turn on but the buttons won't work.
    Problem Solver:
  • 12 Answers
I don't know if it is possible to replace buttons, but I would suggest that you find a certified apple re-seller (or a bestbuy or Apple store) most near you, and drive there and have a pro look at it.
Posted on Jul 24, 2009
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Control locked light is on on my whirlpool duet front load dryer and it won't do anything
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
The is a CL display on our dryer. What does it mean?
Hi
CL means you have activated the child lock or it may have activated after some buttons were pressed. Try holding down the temperature and eco/rapid options together to turn off child lock. If this doesn't work then unplug the washer for 5minutes and try again.
Hope this helps...
Daniel
Sep 02, 2010 | LG DLE2512W Electric Dryer
When I turn the dryer on and dial in the proper settings - the sound is gone. I also don't have any sound (music) when the dryer is finished.
There is a button on the far middle right on the front of the unit that needs to held down for about 5 seconds.
That button will read:
"DAMP DRY BEEP"
*BEEPER ON/OFF.
Hold that button till you hear the unit respond. Now you should hear the sounds. If no sounds, you may have to reset the computer and will need to unplug the unit for 5 min and then plug it back in. You may have to hold the beeper button down to turn on the sound.
If that does not work then you will need a new display board that is right behind the front panel of the unit.
Good luck and I hope that I have helped you.
Jul 16, 2010 | LG DLE2301 Electric Dryer
Melie washer/drier wt945 dryer not working
the motor which controls the movement of the fan is either gone cracked or getting faulty or gone weak.needs to be checked and cleaned or replaced.
Jan 29, 2009 | Miele WT945 Front Load Washer / Dryer
Hotpoint Washing Machine (W540) stopped working, LEDs flash....?
You must get the filter out, as there is a very good chance that this is the prob, keep unscrewing it and try to move it about, then screw it back in again , and then out again, hopefully this will dislodge whatever it is that is holding the filtter in.
Plz rate thiese comments.
Thanks.
Dec 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Whirlpool duet dryer control locked
Hi ... You press the end of cycle signal button for 4 seconds ... This button is on the far right side & it does work!
Jun 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer dryer error code 'check outlet pipe'
the outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
Oct 11, 2007 | Hotpoint Aquarius WD640 Front Load...
Sony NWZ-E436F MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
