Question about Frigidaire FEF366 Electric Kitchen Range
I need a schematic for a Frigidaire Model # RCI-75-59. 1959 unit.
Working on an electric dual oven/ range. Front right top burner unit has a temp sensor that was either found to be non-functional and removed, or problem was not diagnosed properly, some time ago. Found a ''probe'' in lower drawer assembly. Burner has no temp control.
4 Suggested Answers
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
ginko
  • 19396 Answers
SOURCE: burner on range will not turn off
You need to test the heating element, that probably is OK, It looks like the knob control is faulty.
Posted on Aug 27, 2008
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
Why do my top burners do not work, but oven and inicator lights and clock work
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand the burners on your Frigidaire range are working, however you are having trouble with your oven. Do you have an electric or gas range? Can you elaborate prior to your problems any other symptoms or specific error codes before having this issue? Also, may I have your model number please? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem. Thank you!
Jul 13, 2014 | Frigidaire Gallery GLEFM397DS Electric...
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
While using kenmore 790.9621 smooth top range,oven and 2 burners all quit working at same time.Clock and lights working and left front burner heating some but doesn't glow red when on set on high.Dual...
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Kenmore 96212 / 96214 / 96219 Electric...
Burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
My right front burner quit working, can I replace it?
Hi, Could you get me a model # so I can look this up and give you instruction on how to change the burner
Vic
Jul 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I meant to push broil, but pushed clean and my food is locked inside. How do you cancel the clean?
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Get me the model ,number for your oven and I will be able to help you better, Thanks, Sea Breeze
Mar 29, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oct 14, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
112 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
