Question about Toshiba 43H71 43" Rear Projection Television
43H71 43 In Projector
Several days ago I ask whom every could help me.On the broken LINES on the bottom third and top third of my of my green gun all though my red and blue guns can be be adjusted the general belief that one or both of my the stk392-110 wre fried and replaceing them my problem would be solved.I know a semi retired tv tech that has been working on sets since the tube days told me that these two moduals are for red and blue convergance only
and it would not help my green line.he pulled out a board showing the
modules and he even marked them red and blue.being I told him it after a half an hour warm up and I lined up all 9 crosses.the following mouring the green was off again and know after 48 hours only the 3 laterial center crosses line up.he told me to clean the connections with brake cleaner
and if I can't get it the green gun to behave it,s probably ready for the junk
yard .On the other hand he gave to 392-110 he had laying around,after his last heart attack he sticks with tubes and flat screens.I have taken the screen,back and front for better access,after turning down the lamps .i can clearly see the lines in the gree gun.Question#1 if I put in these chips will it fix the green ,if NO WHAT IS MY NEXT STEP?
  • Jethroe Nov 22, 2007
    I cleaned my contacts on the around,below and running off the the circuit board with brake fluid.The next day the green looks great but the red still has bent and treched out lines all though the adjustment still works and I tried doing the same thing I did
    to the green the lines are still stretched.I guess changeing the
    stk-110s is my only road to go down.
  • 205 Answers
I'm no TV tech, but the reading I did on this subject said the 6 amplifiers in the two STK392-110's are used for horizontal and vertical on the RED, BLUE, and GREEN channels.
Posted on Nov 25, 2007
    Genius:
  • 1,694 Answers
Use Toshiba STK392-110T X 2 for exact replacement..........T.
Why is there vertical lines on a smartboard UF65 projector?
1,white spots appeared on screen,means the DMD chip is
broken,you need a new DMD chip.I supply the DMD chip and the
price is USD120
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel,
Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
any questions, feel free to contact me
have a nice day!
Email/Skype: lampdeng@hotmail.com
Aug 11, 2014 | Smartboard Smart Board UF65 Projector Lamp
HITACHI CP-X305 PROJECTOR SHOWING GREEN IN THE CENTOR OF PIC
the Polarizer glass (green) is broken ,you need a new a one
ny questions, feel free to ask me
have a nice day!
Feb 17, 2014 | Hitachi Gst Hitachi CP-X305 3LCD Projector
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Abnormal picture
if it's an xr-32x (as it shows on this pic), it's a dlp projector, not an lcd. therefore no green filter. it has only a colorwheel and a dmd chip to affect the color. if it's not an xr-32x, and it's an lcd projector, replace the green filter. sharp sells the parts for the optical engine. but if it was your service tech that did it, have them replace it.
Jul 28, 2009 | Sharp XR-32X Projector
Abnomal reverse picture
if it was the fault of the technician, they are responsible for the repair. if the green filter is bad, it needs replacing.
The projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Jan 03, 2009 | Panasonic PT-LB50U Multimedia Projector
Hitachi CP-SX5600W colour gun problem
Yes it is if it is same modell on the projectors
Dec 04, 2008 | Hitachi CP-SX5600W Multimedia Projector
Toshiba 43H71 43" Rear Projection Television Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
