Fix my vb script engine on my computer / Windows 7
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
