Question about Protron PLTV-32 Television
Using protron as a monitor with mac
I have a mac computer, I set up my protron as monitor but it now shows "invalid mode" in the VGA mode.  How do I reset?
  • 4 Answers
Need to set resolution and refresh rate on the Mac before plugging in to the TV set - had this same problem with a WinVista machine. According to the documentation, the only supported resolutions are:
640x480 60Hz
800x600 56Hz
800x600 60Hz
1024x768 60Hz
1280x1024 60Hz
1280x768 60Hz
1366x768 60Hz
In all fairness, I cannot get the unit to run in 1366x768, though - get out of range. 1360x768 seems to work OK though. Only real problem with the VGA input is that regular text mode on a video card (more of an issue on Windows machines) does not work.
Posted on Nov 29, 2007
EVERYTHING on monitor is upside down
login in vga mode and change vga resolution settings. For open vga mode restart your computer press "F8" button it shows some modes in that select vga mode and press enter. then change vga resolution in display properties> settings change to low resolution and restart your system
Jul 07, 2010 | Dell Dimension 4700 PC Desktop
FPD1530 (Black) 15 in. Flat Panel LCD Monitor: Screen shows, 'Invalid Mode', followed on next lin...
It means your PC video resolution setting is too high for this monitor to display.
You need to set the resolution to 1024 x 768 @60Hz. Bootup in safe mode (hit f8 during bootup) select VGA support, rest the resolution to 1024 x 768 @60Hz, reboot.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
I put my Hertz way to high and my monitor isnt working
turns out all i had to do was restart the computer in video mode aka VGD or VGA mode
you get to this by restarting your computer and pressing F8 a bunch of times till you get the safe mode menu and select VGD mode and youll be able to fix ur problem from there
Apr 09, 2009 | Fuji FP-988D 19" Flat Panel LCD Monitor
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Feb 06, 2009 | Compaq Computers & Internet
Akai 32LW7 _connection to Laptop
I believe that you have connected it correctly since the Windows log-on is displayed. It may be that the Screen Resolution of your desktop is a bit high and therefore would have to be lowered to match the capacity of the Akai 32LW7. Pls try 1366 x 768 pixels or lower. You could also lower the laptop's screen refresh rate. Additionally, some laptops have to be toggled to activate external VGA by pressing Fn + F? keys to cycle through LCD, LCD + external, External only. The F? key would be the one with the monitor icon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 31, 2008 | Televison & Video
'input not supported'
just had this problem and just fixed it. all you need to do is unplug it directly from the outlet then turn on it worked for us so hiopefully it will work for ya'll
Sep 07, 2008 | Computers & Internet
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
VGA
Monitor outputs from PCs can be very fustrating. First of all, is the PC a laptop? If so most of them do not have a dual monitor capability for supporting an external monitor, or if they do it can be difficult to get it to use both monitors at the same time. Try updating the drivers for the video board. Most of them are sold with drivers that are outdated.
Dec 20, 2007 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
386 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
