Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Brushroll in electrolux oxygen+ deluxe
Im just wondering where you can buy a brush roll for the electrolux oxygen+ deluxe
  • 328 Answers
Is the brush roll not working at all? Check the teeth at the sides of the brush roll by opening up the electric head. If it has completely been destroyed you may have to buy another new head for it. Separate brush rolls are difficult to obtain and work out more expensive sometimes than the electric heads themselves.
You may have to contact the Electrolux cust services in your own country. Check by Electrolux.com
Posted on Jul 25, 2009
My electrolux vacuum has a red light that won't turn off and my brush roll won't work
Check the belt and the end bearings are free by hand. (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly...
Aug 22, 2014 | Electrolux Vacuums
Makes heavy vibration noise when turned on for carpet and belt is good
Check the brush roll and the end caps to insure the brush roll is spinning freely. If there is wear or damage to the brush roll it can cause it to be out of balance and vibrate
Jan 12, 2014 | Electrolux EL5020 Vacuum
Hello, My Electrolux Oxygen motorized brush stopped working. How do I determine if it is the switch, a belt or something else that is causing the motor not to work?
Hey Lee,
We had the same problem and after taking it to a service guy who didn't even want to LOOK at the vacuum, it occurred to us to plug the powerhead brush directly into the handle and it worked! So, we were able to determine that the problem was the tube - not the brush.
We ordered a replacement tube.
Hope this helps.
Nov 06, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have a 15 yr old electrolux genesis upright vacuum cleaner that I can't get the roller out, to replace the belt.
There are two small screws at the end of the brush roll on some of these. There is a bearing block recessed into the housing at a slight angle to help tension the belt, so it comes out at an angle as well. It often fills with grit and you must clean the grit out carefully without damaging the blocks or housing. Sometimes WD 40 helps is the area has any rust build up. Then work a large screwdriver under one end the brush for leverage being CAREFUL not to damage the brush housing. Do not soak with WD40 as it will also get into the brush roll bearings
Jun 09, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Auto rewind for the electrolux oxygen 3 ultra
HI
If this isnt working correctly, take it back. It wont get better
Feb 20, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need source for Electrolux Oxygen parts!
Some parts can be found here: http://www.vacuums24x7.com/elox3ulcocav.html
Unfortunately they don't have the part I need.
Jul 15, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power Head for Electrlux Oxygen Ultra
I work for Aerus Electrolux. My office # 570-326-1731 Call me and I will help you order the part. Liz
Feb 26, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
226 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
