SOURCE: Lexmark X4850 wireless set-up
I have a Lexmark X4850, every time I print a job it prints a blank page first then the document. I have tried to tell it to print 1-1 or 1-3 but it continues to print that blank page first. any suggestions.
SOURCE: Lexmark S405 Paper Jam
Hello there ok
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
http://www.printertechs.com/tech/mkinst/mk-1300-5fuser1.php
SOURCE: my lexmark interpret s405 is
There is a recent firmware update that fixes the problem you are describing. Click on this link: Lexmark Interpret S405 Firmware Update to download the update. If you encounter any problem updating your printer, please contact Lexmark technical support for additional assistance. Thanks.
Your printer and the devices trying to print from it should be connected to the same network. If it is, download our LexPrint app to your iPad http://bit.ly/IMbDlq. Since the Lexmark Pro205 is not AirPrint compatible, you would need the LexPrint Listener installed to a host computer.
Our latest Inkjet printers are already compatible with AirPrint.
SOURCE: Lexmark Pro 915 wireless print problem
Try set a static IP on your printer. Check the steps in this article: http://bit.ly/SxORCU.
After setting a static IP, set the network port to the IP address that you provided to your printer or you can reinstall the drivers.
Lexmark just recently released the Lexmark Mobile Printing Application for use with Android devices, however, the application is supported only on most laser products and the very latest inkjets that are coming out for 2011(the Lexmark Pro715 and the Pro915 are the only models announced at this point.).
