Question about Zenith ZEN450 Remote Control
The tv screen is blue and i can't get the remotes to change the channel or show me the guide
  • 10,515 Answers
Let me inform you - Blue Screen has nothing to do with Remote. This is a Hardware problem. More likely, you need to get it repaired by calling a tech.
Before you call, make sure you have the correct connections. Usually this might occur, if there is no Signals or if you might have Turned DVD/VCD on.Check the manual to turn it off. Also, plug off the cord for 30 minutes and then again plug in the Power cord and see, if that could help you.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 24, 2009
The humax remote formerly managed all functions with TV now won't turn TV on, when tv on won't change channels, show home, guide any functions, but will change volume.
If you have changed your TV, you'll need to change the TV code in the Humax remote. See the TV code list at the back of the Humax User Guide.
Jun 27, 2015 | Humax Televison & Video
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
Dish receiver 322 dual tuner will not give channels when select is pressed on remote . have replaced remote with no results . blue light on 2nd reciver of box
The situation you explained, klipjointhai, is pretty interesting and I would enjoy the opportunity to help! What does show on the screen when you press the Select button on your remote? Also, are you able to make the TV guide come up when you press the Guide button?
Jul 26, 2011 | Televison & Video
Screen is all snow and channel 4 shows in the upper right hand corner. TV needs to be on channel 3, but trying to change it manually does not work; therefore, satellite tv does not work. I've checked...
Check your TVs settings. Check if channel skip option in on. If it is on, this type of fault occur. Turn it to off if it is in on condition. If the blue back screen option is there, just turn it on to avoid grains on unused channels.
Oct 13, 2010 | RCA F32649 32" TV
One of our TV's was being accessed by someone in the neiborhood. I found in the manual how to change the remote code. After doing this the TV is locked on one channel. I did reboot. The remote is working...
Hi! I will be more than glad to assist you in this concern. Lets Isolate the problem, press 1st the sat button once on the remote that is giving you a problem. the sat button should light up and check if you could pull up the guide or can change the channels. if there is still no response, bring with you the remote conrtol that is giving you a problem on tv1, turn on the tv and it should show a picture, go to the fron tpanel of the receiver and press the power button once to turn off the green light, once its off, the tv will go into a black or snowy screen, press the up button on the front panel of the receiver until it shows the system information. look for the primary and secondary remote address, ex, primary remote address is 1 on the white box and 1 on the green box, secondary remote address is 2 on the white box and 2 on the blue box, how to reprogram the remote, press and hold the sat button on the remote that is giving you a problem and wait until all lights lit up, once it lit up release it and press any number from 1 to 15, but lets choose 9, then press the pound button (#) that is under number 9, once you press pound button, the sat button should flash 3 times, then after it flash, press the record button, that is under the cancel or view tv button., you will notice that the secondary remote address was change from 2 to 9. to save the setting, get the remote1, select done on the screen and it will show a black or snowy screen. to check the remote 2 if it works, press the sat button once and the the big red power butto, the blue light should turn on if there is no blue light but there is, the blue light will turn off, then before you go to the tv2 location make sure that blue light is on and then check on the tv2 location if you could change the channels now. just incase that the problem is still there, check the remote antena on the back of the receiver, make sure that its on the upright position to broadcast the uhf signal properly.. that should fix the problem. if just incase the problem still exist, call 1800-333-3474 ask for a replacement of the remote..pls feel free to get in touch..if you have any query
Jul 04, 2009 | DISH Network 322 DTV Receiver
Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Mar 21, 2009 | Vizio VX20L 20 in. LCD TV
Zenith ZEN450 Remote Control Logo
44 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
