SOURCE: clutch
it is a hydraulic clutch system, especially on the 89 prelude. I have one the exact year model, and i had a hole in the slave cylinder hose going to the transaxle from the slave cylinder.
To refill the reservior, use DOT 3 brake fluid. The reservoir is located just to the left of the brake fluid reservoir underneath the hood on the driver's side firewall. you can't miss it.
SOURCE: Mower Belt Won't Engage
The fact is that belts don't stretch. They wear down on the sides, causing them to ride deeper in the pulleys and they APPEAR to be longer. Check belt "width" to see if it is less than one half inch. Most craftsman riders use half-inch (AKA: "A section") belts.
Testimonial: "I removed the mower & checked everything - pulleys, bearings, mandrells, springs. All OK. Re-assembled and it works again. Thanks for your feedback."
Check the spring to see if it has snapped anywhere within it's coil.
Remove the cable and check operation of the pedal and spring mechanism.
If all is well, then with a lever, check that the clutch release arm on the gearbox is operational. If that is also sticking, then you will have to remove the gearbox to investigate further.
If not sticking, then also remove the clutch cable outer sleeve, and replace.
