Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon pixma mp800 error code 6A00
I have a error code 6a00
    President:
  • 2,306 Answers
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Posted on Jul 24, 2009
Hi sonu myname is mandeep i have a problum with my canon mp800 printer it has a paper jam alarm can u help me
Yes Sure!!!!
Just Take a Size 10 Envelope Insert it on to the Paper Feeder and Move the Envelope Back and Forth for about 20 Times as Fast as you can!
Once Done with it, Turn the Printer Upside Down and Gently Shake it so that if it has any Obstacles in it Would Come Out.
Once Done with all this Turn on the Printer and Check If you still have the Same Error.
The Printer has a Hardware Problem and needs to be Replaced.
Good Luck!!!!!!!
Oct 22, 2011 | Canon Pixma MP800 All-In-One InkJet...
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Canon MP800 Error code 6A00 alarm flashing .turned off overnight ,turned on not working ,still same code and alarm . Will not do anything . Thanks ...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Canon Pixma MP800 All-In-One InkJet...
The printer is a canon pixma MP800, error code 6A00
Hi
Hope it works for you
Solution 1:
Solution 2:
Solution 3:
Mar 29, 2009 | Canon Pixma MP800 All-In-One InkJet...
Canon Pixma MP800
you need to clean and calibrate them..you'll need to do that from the print manager, under maintenance
Apr 14, 2008 | Canon Pixma MP800 All-In-One InkJet...
Error 6A00 mp800
hi 6A00 is a problem with the sheet feed unit.it appeared that the print head carriage was stuck move the carriage manually for a few times left to right the problem was resolved. and also check for any torn paper piece in the printer.you can also blow the air in printer for dust and paper piece.
Jan 01, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,230 people viewed this question
old marine
old marine
