Back to:
Tags:
GE Spacemaker  Microwave Oven
Removal (by 7 users)
posted by LameBrain on Nov 21, 2007
Our GE Spacemaker just went on the "blink" I am going to replace it but I can't figure out how to remove it or where the mounting screws are located, can anyone please help? Thanks, Frusterated Frank!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by peaveydubya, posted on Oct 31, 2008
Can't remove GE Spacemaker Microwave probably from late 80s early 90s
Comment by Guest, posted on Sep 08, 2008
Spacemaker model JVM59
Comment by Guest, posted on Sep 06, 2008
how to remove
Comment by Guest, posted on Apr 12, 2008
removal
Comment by Guest, posted on Mar 26, 2008
want to remove the microwave oven
Best Solution
posted on Sep 20, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Removal:
I don't want to Accept this solution
Solution #2
posted on Nov 22, 2007
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 3305 votes
You can download your model's installation guide here:
http://www.geappliances.com/service_and_support/literature/
Thank You!
Can you Help with these Microwave Ovens problems?
GE Spacemaker (JVM1640SJ) Microwave Oven
everything run but food will not heat up
I know how to get the panel off of the microwave door, but...
What bulbs are they? I don't have a maual and my wife lost...
Thanks for the info on the replacement of the membrane....
i have a ge spacesaver 1800 neither bulb works under the...
6 Other Users Have The Same Problem - Continued
Comment by Brokentee, posted on Nov 28, 2007
I have the same problem as LameBrain. Unable to find the installation manual. All I found at GE was the use and care manual.
Loading problems.
Repair Service
Find Microwave Oven Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
