Question about HP Televison & Video
HP PL5060N Went Pop
Need to find the part number for this board: https://cid-39c98469566291ab.skydrive.live.com/self.aspx/HP-PL5060N/HP%20PL5060N%20Board.jpg
You can see in the top middle of the picture that there used to be a ''transister'' right there. I belive this is the problem. Sound is good. Picture is viewable but dark with very slow refresh. I'm no expert but something used to be there on the board...
Plasma HP PL5060N ticking noise and flashing. Which board need to replace YSUS or ZSUS?
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 25, 2017 | HP Televison & Video
42" hp plasma made a popping sound & went out
The TV needs professional service or replacement.
Feb 13, 2014 | HP PL5060N 50 in. Plasma HDTV
Hi my tv when its on.the source menue will apear on its own and go up and down the menue after 30 minutes it will go to the blue screen whats causing this
You either have a bad keyboard on your TV or the main board is bad. If you disconnect the key board after the set is on and the symptom does not change - replace your main board
Apr 18, 2012 | HP PL5060N 50 in. Plasma HDTV
I have a HP PL5060N My TV is going nuts. The channels change on their own no matter if I am watching TV, gaming or watching a movie. I just get booted out of where I am or the TV show to watch the new...
Take the tv aparts.Take the tv manual control board aparts.Reajusting the board and screws it back in.Should solved ur problems,if not than the whole tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal board plug into it,this board have intermittent problems and the causes.Try website like Ebay.com t buy a whole refurbish tv Tuner signal board for the replacement.
Dec 06, 2010 | HP PL5060N 50 in. Plasma HDTV
I am looking for a power supply module for the hp pl5060n plasma tv
try to find a part number on the board. you can punch this # into google to find a part. hp used different brands so you will have to get the number off the board. look for buldged caps, maybe you can fix the board if it has some. google "bulged cap" to see what they'll look like
Jun 01, 2010 | HP PL5060N 50 in. Plasma HDTV
Heard a "pop" then went dead.
Sorry to say - it sounds like the 'pop of death'. The 50" Zenith plasma is very common for having a power failure issue. The problem resides in the Y-Sustain board in most cases. The Toshiba 50HP66 and Vizio P50HDM (as well as LG and HP 50" Plasmas) also have the same issue as they all use the same PDP Panel (plasma panel). The parts are manufactured by LG/Zenith Corporation. Since your Zenith is the model i'm thinking of (Z50PX2D), then the board you would need is the following:
http://www.discount-merchant.com/PCB-Y-SUS-MAIN-FOR-HP-HP-PL5060N-TELEVISION-p/2 761-hp-hp-pl5060n.htm
The above site is the ONLY place that I have ever found selling this hard to find part and the price is reasonable. If they are out of stock on that exact link, just search for 6870QYC004C on their site and you might find one that is in stock.
NOTE: Before making any purchases, please check the part and make sure it is what your TV needs. I am simply making recommendations and trying to point you to the right direction.
Dec 22, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
50 inch HP Plasma Gone Wild...
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Dec 17, 2008 | HP PL5060N 50 in. Plasma HDTV
Televison & Video Logo
171 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
