What causes a virtical line in two places in the screen one is in the center aprox.a quarter inch wide the other is about three inches away and abit bigger there is a grey look ,no picture in them at all
Does a quarter inch quilting foot come with the machine, if so what does it look like?
If your machine is considered a "quilting" machine, it may have a 1/4" foot included. However, most machines do not include the 1/4" foot. A quarter inch foot looks a lot like a basic presser foot except the edge should be 1/4" away from the needle.
FWIW, you can achieve a 1/4" seam by placing a ruler under the presser foot and gently manually lowering the needle point until it rests on the ruler's 1/4" mark. The ruler's edge would then be exactly 1/4" away from the needle. You can place a piece of painter's tape (on the sewing surface) adjacent to the ruler edge and this would serve as your quarter inch guide.
Even if you decide to purchase a quarter inch foot, in my experience, none of them provide the "scant quarter inch" seam for piecing. Other than marking a scant quarter inch measurement on your sewing machine, achieving it will usually take some testing to determine what constitutes a scant quarter inch on your machine.
3 Ways to Master the Perfect Quarter Inch Seam
http://quiltville.com/quarterinch.shtml
Scant 1 4 seam allowance
Accurate Piecing Basics Quarter inch Seams WeAllSew
Jan 18, 2018 | Sewing Machines
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
How can i fix gray line in center of screen of my vizio e320vp
Check lvds cable and ribbon cables going out of t-con board going to the lcd panel.
Nov 14, 2011 | Televison & Video
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Blade will not stay on cutting mark, even a straight line. My blade looks like a quarter inch on a nine inch band saw.
clean dust off the wheels, center the blade get it tracking and tension it so it has a medium high to (wide blade) high pitch (narrow blade) twang like a guitar sting when plucked with the saw turned off
Feb 19, 2011 | Ryobi 9 in. Benchtop Band Saw
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
Picture has mark please helpfind the source
Anything from video processing to screen drive could cause a problem like this...accordianman
Feb 27, 2008 | Samsung HC-P4363W 43 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
