Question about Toshiba HD-A20
HD-A2KU Blank screen...not recognizing new HD-DVDs....error message sometimes comes up that says unrecognized DVD format. I have an HDMI cable hookup. The front panel is saying 1080p. Do I need a FIrmware update? if so which one? Again this is for a Toshiba HD-A2KU
  • 3 more comments
  • giannotti1 Dec 01, 2007
    Have the same issue with my HD-A2KU. Still seeking a solution.
  • Anonymous Dec 17, 2007
    HD DVD is not dvd format error
    firmware 2.7 did not fix problem
  • Dogwood Feb 02, 2008
    HD-A2KU brand new disc freezes about 20 mins before the end of the movie. This happened almost the same spot on 2 other discs. I've done the firmware update but it didn't help. I also cleaned the disc. Error message is: 408bc504
    Error code 408bc504 Brand new disc freezes about 20 mins from the end. THis is the 3rd disc to do this. THe update did not help.
    Thank you for any help.
  • sherryp39 Mar 27, 2008
    I am trying to play a DVD that has played before but get message 'This disk is not DVD format'
Same here. This player used to work fine. Now I'm ready to start saving up the 350 clams for a PS3. I'm tired of the Toshiba junk. I wish they would give me my money back, bastages.
Posted on Sep 14, 2008
Yes, the firmware up to v 2.5 will correct your problem
Posted on Dec 08, 2007
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
Thompson DVD DTH271E refuses to play HD DVDs but fine normal DVDS, cant seem to get any help via Thompson, & think may need "firmfare" update? New machine but in Spain & language...
Hello there.
Push "Play/Pause" and "DVD Rec" on the dvd recorder a few seconds to see the service menu. There you can find your firmware version.
Post back the version for us.
Hope this helps.
May 06, 2008 | Televison & Video
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
HDMI not working Sony BDP-S350
plug the sony player into your home network via a network cable ( should be a network port ( RJ45 port ) on the back of it and then update the firmware - unless its already the latest version, if it is then post back with any error messages or whats happening exactly when you try to select HDMI or is it greyed out ?
Jun 02, 2009 | Sony BDP-S350 Blu-Ray Player
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Will not play HD DVDs. & will not record
First off this is not an HD dvd player it is a dvd player that has HD upconversion. secondly if you want to record a cable show you will need to push that into the dvd recorder with the a/v input.
Dec 29, 2007 | Samsung DVD-R135
Can you connect to upconversion DVD Player for HDMI performance
The TV supports 1080i so if your hardware is plugged into the Component Cable Connection for Digital TV on the back the signal will come out 1080i as long as the hardware supports the size.
For example, my 360 is connected like this and when the dvd player is in use it upscales from the 480 format dvds use to 1080. More on the HD-DVD for the 360 and how it handles the sizes here:
http://www.engadgethd.com/2006/09/21/xbox-360-hd-dvd-playback-maximum-1080i-via-component-1080p-vga/
Kind of an old article since the newer 360s have hdmi and support 1080p that route.
Hopefully this helps.
Dec 16, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Hdmi
Its not designed to play HD DVDs, the model has HDMI connection in order to connect to latest output devices, viz flats panels and LCD tvs there by having a common audio and video cable. your model has a feature to upscale the normal DVD singal to match the quality output of hull HD TVs, hence the HDMI out put, do not confuse this with HD compatiability.
Go to the link below to check the full specs of your system.
http://www.consumer.philips.com/consumer/en/in/consumer/cc/_productid_HTS9800W_55_IN_CONSUMER/DVD-SACD-Home-Theater-System+HTS9800W-55
though yours is a high end set, but its not HD disc compatiable.
Regards
Benam
Nov 14, 2007 | Philips Cineos HTS9800W System
TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Nov 03, 2007 | Toshiba HD-A20
Toshiba HD-A20 Logo
295 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
