Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
Schlage Keyless lock intermittently won't unlock
I installed one of these about 6mos ago and every now and then when I come home it won't open. I can correctly enter the combination and I get the normal green light and unlocking sound but the handle does not open the doo. I can enter it over and over and same thing. It seems like if I push very hard on the knob (as if closing the door) it seems to help it work but not always. I have a hard time reproducing it though so I can't find any indication of the cause (I have tried closing the door harder, entering the combination faster or slower and a few other random things to no avail). It seems like it is happening more frequently but that might just be b/c I am getting more annoyed by it. I have a second one on another door and when I get locked out I can go there to get in. I vaguely recall having a problem with the other one that I looked up online and found a solution for but don't recall what it was. I don't use that door so much so not really sure if it has the same problem or not but am going to start using that one more to find out. Anyone have any suggestions?
  • 10,865 Answers
I would recommend that you replace the battery and see if that solves your problem. If it does not, get back
Posted on Jul 24, 2009
How to unlock my Apple iPod model no.a1199 if i forgotten my passcode
Unlocking iPod You can unlock iPod in one of two ways:
  • Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
  • Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
Sep 25, 2015 | Apple Audio Players & Recorders
What does it mean if the red and green light flash together???
Do you have a key ??? try your combination and A or B
Open with key insert new batteries and reset combination.
Feb 14, 2015 | Honeywell Safes Top Opening Drawer Safe...
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Safe(DSW3607). Battery is working but door won't open when combination is entered. It stuck in the past but I was able to open it eventually. Now it appears as though the handle will not turn all
Internal batter is low...look for two pin points on the outside of the combo and attatch a new battery temporairly then work combo. Insert new battery when you get it open. Hope this helps Ed
Oct 02, 2012 | Sentry Fireproof Safe
Lock won't work
Change your battery & reprogram your lock. Follow this link.
Give this a moment to load:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
May 17, 2012 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
How to open screen lock
Hy. If you have an iPod and you want to unlock it, you can do this in 2 ways:
Apr 26, 2012 | Audio Players & Recorders
Schlage keyless deadbolt BE365PLY716 Will not unlock. We put in the code the light turns green we turn to unlock but it just spins like it isn't catching on whatever it needs to to unlock...help!!
Your problem sounds like an internal mechanical one. Schlage has a lifetime warranty against mechanical defects and a 1 year warranty on the electronics, if you are the original owner. Just so you know.
Here is the contact information for Schlage:
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Please contact them. Hope this helps!
Feb 05, 2012 | Schlage Locks & Locksmithing
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
794 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
