Question about Maytag Portable Air Conditioner M6P09S2A
Top tray not draining
I have a maytag model #M6P09S2a portable air conditioner with a top tray not draining. I also took the back cover off and don't see any drain from the top tray to the bottom tray.
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Posted on Jul 25, 2009
  • Cindy Ray Sep 08, 2013
    Did you do this yourself?
Old Maytag portable AC leaking. an hwar water when I move , don't know how or where to drain
Make sure the drain line is not stopped up and that the drain pan is empty. The pan relay on the heat from code see to evaporate water and with a full pan that isn't going to happen. Drain line or pan full.
Jun 05, 2016 | Maytag Heating & Cooling
How do I drain the water from unit before storing
Drain from valve at the bottom of the back of the unit. Look at page 6 of the instruction manual here: http://usermanualnmpeb08f2a.yolasite.com
Aug 25, 2012 | Maytag Portable Air Conditioner M6P09S2A
My son gave me the portable Maytag ac unit. I hav eit operating now and have it resting on the lid ofa rubber made container. So far I have suctioned off 3 large bowls of water. I can`t find how to a
There should be 2 ports in the back or on the side with screw on caps take those caps off and you should see some rubber stoppers when you remove them all of the water will drain out. From what you are saying there should be alot to drain out so be prepared for it to pour out.
Jul 28, 2012 | Maytag Portable Air Conditioner M6P09S2A
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
Maytag model m6p09s2a*b leaks water doesn't
Make sure it's mounted correctly..the back of the unit shopuld be slightly lower than the front or water can leak over the pan in the front.
Oct 10, 2009 | Maytag Portable Air Conditioner M6P09S2B
Model M6P09S2A Maytag Portable Air Conditioner/Manual?
I have the M6P09S2A Portable unit that is leaking water everywhere. I have to place it in a large bin to keep it from draining on the floor. Any solutions?
Jun 29, 2009 | Maytag NMPEB08F2A Air Conditioner
Red light came on and air conditioner will not turn back on
I had a similar problem on a B&Q air conditioner and all it needed was the drain plug removing and the water draining out - then it started back up straight away
Jan 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Leaking in the maytag m6p09s2a*b
Do you have the Manual to read the trouble shooting page?
How old is the unit?
If not here is a web site to acquire the manual
http://homeappliance.manualsonline.com/ex/thread/view/idThread/326907
Bless you ngafm Waiting for you answer!
Aug 21, 2008 | Maytag Portable Air Conditioner M6P09S2A
Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Jun 13, 2007 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
1,088 people viewed this question
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
