Kenmore 90 series top load
Water fills up tub and won't stop all the way to the rim..
  • 2 more comments
  • abemina Nov 29, 2007
    I fixed it!! Thanks a lot guys. I found the hose to the water level selector was unplugged. Plugged it in and it worked!
  • stepchild Dec 11, 2007
    water leaking from bottom during spin cycle
  • Spicy1 Feb 23, 2008
    I went to wash a load of clothing and noticed that water was leaking from the bottom of the washer. I stopped it and attempted to spin out the water that was in there needless to say the water leaked out again. I unplugged the machine from the wall. Question " How exactly do I fix this?"
  • rigneyew May 17, 2009
    My Kenmore 90 series starts filling the tub and does not stop and overfloods....
  • 249 Answers
Blocked pressure switch bottle.clean out bottle.Close.
Posted on Nov 21, 2007
  • eamonn close Nov 21, 2007
    good luck easy to fix .Close.Ireland fixed hundreds with the same problem,bye bye
  • eamonn close Nov 29, 2007
    the small hose that was off,go's to the bottle ie ,water level selector follow hose to find bottle.Close Ireand
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
I have a Kenmore 500 top load washer that doesn't hold water. As it is filling for the wash cycle all the water runs down the drain
The drain hose outlet must be higher than the 'full' water level in the tub or the water will syphon out until the tub water equals the hose height. If the drain system you are using for the washer is floor level, then you need to install a vertical pipe (1-1/2" minimum) to place the hose end into at the top and it should eject the water through a 90 degree elbow onto the floor at the bottom. There are more elegant solutions, but this will stop the tub from self-draining. Good luck!
Aug 05, 2010 | Kenmore 22422 Top Load Washer
My kenmore 90 series filled with water and went it got to the rinse cycle it quit working and just started making a grindling sound. help please
sounds like the motor coupler broke. it's a plastic piece near the motor and very easy to replace.
here'e a video you can watch to make it easier:
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Filled with water and stopped working
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at,,, Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: You do not have to drain the washer to complete this repair. Once the lid switch is adjusted or replaced, the water will drain. This will save you time in having to bail water.
Jul 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series heavy duty washer
If it fills up to normal level on other settings then the water selector switch is bad.
Look at the back side of this switch and you should see a tube connected from the switch to the lower part of the tub. Take the tube loose at the switch and blow through to check for any blockage. Look at the tube for holes.
Nov 14, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
