SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
SOURCE: how to reset lexmark36 ink cartridge
try to reset ur printer
press and hold on power button for about 20 sec then press hte power button again
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
SOURCE: My Lexmark X5410 Printer will not recognize a refill cartridge.
Hi there
This is the same old story with Lexmark printers, you cant do any thing about it the chips have a small fuse inside them and soon as they emty it blows the fuse, and thats it so I beleave the only way is to buy new ink, or a diferent printer.
Not know any fix for them myself sorry.
Can try.
Turn printer off. Unplug power cord and other cables. Wait 30 seconds. Plug cords and cables back in.
Also seen this on the net.
Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
but yeah, best bet, never ever buy lexmark.....:)
http://www.fixyourownprinter.com/forums/inkjet/35235
If that doesn't work, try disabling your ink monitoring software.
All The Best Pineworks
Testimonial: "Thanks for the quick response. I'll try these things...and not buy Lexmark again."
