Question about Mitsubishi WD73727 73" HDTV
My Mitsubishi 73" television has vertical lines spaced evenly across the screen. Any help?
    President:
  • 2,187 Answers
Identify first if the lines are caused by interference, bad cable connection, loose cable ports or bad line. You can do this by attaching another TV to a signal source or trying out a different source such as a DVD player. This is to isolate the problem. If the problem is still present regardless of the source then the issue could be on the board. This might be brought about by soldering that had come loose or a bad IC. For know I would advise to have the TV disconnected overnight to reset it and see if the error is just within the TV's software. Proceed with the other steps once the problem still exists after.
Posted on Jul 24, 2009
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
Vertical Lines
Hi I can try soling your problems
Feb 22, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Vertical lines
hi there.. try this link they talk more about this problem and there is a picture lets see if your problem is similar to the one on web
your image is like this one?
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1283&p=4322&hilit=Vertical+lines#p4322
Mar 05, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Vertical lines appear on screen...
You have a defective light engine. Contact RCA support. Sometimes they will warranty these even after the 1yr warranty has expired.
May 16, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi cs 35203
That sounds like vertical failure. Does the blue line run across the screen from side to side? Try resoldering the vertical output IC and see if that straightens it out. This is sometimes been a problem with that chassis. Let me know how you make out or if you need additional help.
Mar 29, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Open Questions:
See all Mitsubishi WD73727 73" HDTV Questions
Mitsubishi WD73727 73" HDTV Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
