Question about Whirlpool GU3600XTS Dishwasher
NOISY DISHWASHER WHIRLPOOL GU3600 - Whirlpool GU3600XTS Dishwasher
  • 10,865 Answers
If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Posted on Jul 24, 2009
Noisy Dishwasher
it is a capacitor to start the motor for the next cycle. I think it is inside the door. you may have to call a tech.
May 19, 2013 | Whirlpool GU2300XTVQ Builtin Dishwasher
Food particles are being thrown back onto dishes during rinse cycle and the rinse cycle is noisy.
i would suggest you dont put the food particles in the dishwasher in the first place,it sounds like you need to clean your filters out as it is a funny fault,
Apr 12, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Dishwasher noisy
could be something in the pump, or the pump itself (wash or drain) need more information as to when it makes the noise and does the machine still work or not.
Jan 07, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher noisy needs new motor
You may not need a new motor. If it is "buzzing" it may need a new small run capacitor - that can dry out and fail.
If the pump is noisy (but working) it may need clearing - or if worn - replace the pump.
Only replace the motor if the bearings are badly worn or armature damaged.
Sep 30, 2009 | Home
When i start the dishwasher it will run very noisy and then stops
Sounds like your motor bearing is wornout.Noise is either from Motor bearing or impellor, It will depend on make of Dishwasher. But if it quits after running noisy and over 7years old, get a new one.
Apr 27, 2009 | Whirlpool GHW9400SU Front Load Stacked...
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher motor is more noisy than it used to be.
Mine does the same thing all kinds of different sounds. This is the 2nd replacement
Jun 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU3600XTS Dishwasher Logo
676 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
