Question about Samson Audio Players & Recorders
How long can a UHF wireless mike powered by two AA panasonic heavy duty batteries last? (constantly transmitting as in spruiking) Thanks
3 Suggested Answers
seandc
  • 18 Answers
SOURCE: No power
You need to buy autovolt adaptor (8 volts)
but never use adaptor and batteries at the same time.
try our site www.magicmic.com
email us customerservice@magicmic.com
try cleaning the chip. you can clean it using a pencil eraser.
You need to remove the chip from its casing
make sure to take note of the position of the chip inside casing- (inverted song chip will not make mic power on)
try erasing the gold terminal pins of the chip - gently) then return it properly..
Posted on Mar 08, 2009
diodeic
  • 1622 Answers
SOURCE: Anchor 16 channel UHF wireless.
Disable muting if you do not hear any signal from the microphone. Even if the transmitter unit is powered on, if muted it will not send any audio signals to the wireless receiver. Right next to the word "mute" there is an arrow pointing to the left; move the switch away from the direction of the arrow to turn off the muting feature and check the microphone again to see if it transmits any signals.
Replace the batteries in the transmitter unit if you still do not hear a signal after ensuring that the transmitter is not muted. The transmitter fits a standard AAA battery in the battery compartment. The battery compartment cover can be removed by hand by applying gentle pressure to the logo on the transmitter unit.
Remove or power down any audio and/or video equipment near the transmitter or receiver that may cause interference. The wireless microphone system operates on RF frequencies, so any equipment installed near the transmitter or receiver that uses RF frequencies (such as RF remote controls or wireless speaker systems) could cause audible humming, buzzing or popping while you are using the microphone. Temporarily turn off the devices or remove them for testing purposes and check the microphone again to see if the signal is clearer. If it is, place either the interfering equipment or the system in a location so that RF interference is no longer an issue.
Hoping this will help in solving he problem....
Posted on Sep 19, 2011
My radio is not transmitting what could be wrong
When the batteries are reaching the end of their life or in need of charging the first thing that is likely to happen is that the unit will be weak when transmitting while receiving just fine. This is because it takes a lot more power from the batteries to transmit than to receive. Try a new set of batteries or if rechargeable then try charging the unit. With regard to regular batteries, make sure your batteries say "alkaline" on them somewhere since they will last much longer and also are more likely not to leak inside which can ruin your radio. Ignore labels on batteries that read "super heavy duty" or other such nonsense. Look for one and only one word "alkaline" on them and buy any brand you want to since cheap or expensive they are basically the same. Don't waste your money or risk your radio by using anything but alkaline batteries.
Hope this helps.
Dec 08, 2014 | Radio Communications
How long will my four aa batteries last in my walkie talkie
Typically you can expect the AA batteries to last about 18 hours using the 5-5-90 rule. (5% of the time your are transmitting, 5% receiving, and 90% standby) If you transmit/receive more than this the time the radio would go would be shorter.
Best regards.
Jun 04, 2014 | Midland LXT310 2-Way Radio
Where do I get Extra Heavy Duty Green R6P UM AA 1.5V Batteries from?
http://www.alibaba.com/showroom/aa-battery-r6p-1.5v.html
Sep 05, 2012 | Cameras
Wireless lapel mic uses batteries at the rate of one per day. Even if the unit is off, the battery still goes dead..
As long as the battery is in the microphone, the microphone is on and transmitting. Even if your receiver is off. Remove the microphone battery when not in use. Life expectancy of an Alkaline battery is about 4 to 8 hours stage time. Only 1 to 2 hours for heavy duty batteries.
Feb 23, 2010 | Telex FMR-500 Microphone
I have a samsung 860 digital camera ang my problem is the lens... the lens is still retracted even its turned off... before it happened the camera have a low battery.. and when i charged the battery for...
This may be similar to another solution posted. Try heavy duty batteries - I used ACDelco Super Alkaline, but any brand of "heavy duty" AA should work. Make sure battereis are not cold; low temp causes any battery to lose power. If fresh heavy duty batteries do not help, it may need professional service. (DO NOT try to force the lens back to retracted position - something WILL break.)
Dec 18, 2009 | Samsung S860 Digital Camera
First, I am a 1st class amateur, so jargon is ?Greek? to me. However, I am studying the manual dilligently. My question concerns the batteries. I am using Panasonic Heavy Duty AA?s. I am always very...
It's essential that you state the exact make and model of your camera.
But in general many are incompatible with regular AA batteries (even heavy duty ones)and instead require that you use NiMh or even Li-ion rechargeablesinstead. The voltage, internal resistance and discharge characteristicsof these are significantly different to regular disposable AA batteriesand so the camera will report "battery empty" prematurely.
Check your manual again and if I've answered your query please return the favour by rating my answer. If not then please add a comment to my posting adding the required info for a definitive answer.
(Sorry for the repeat, FixYa ignored my instruction to post the above as an answer rather than a clarification request).
Jun 26, 2009 | Olympus Cameras
The 2 red lights on the right side of the mouse receiver are on.
usually the receiver is powered via the connection to the pc. ( ps2 style sockets usually green and purple ) dependant upon make/model of wireless. i would suggest replacing the batterys. on the mouse. these do use more power than the keyboard. roughly 5 to 1 or more.
after replacing the batteries. ( 2 x AA Or 2 x AAA ) press the button on the bottom of the mouse, and should have a button on the reciever. to syncronise the pair together.
In regards to your question, you may have 2 lights on the receiver. 1 for transmit, and 1 for receive.
new batteries should solve this problem.
Thankyou for using Fixya.
Mike @ Compurepair.
Jan 05, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Shows empty battery even with new batteries
If they're AA, don't use "HEAVY DUTY". They don't have enough power. Use alkaline or rechargeable, and recharge at least 15 hours even if your charger show they're fully charged after a couple hours. Please leave feedback if this helps.
Jul 26, 2008 | Olympus FE-210 Digital Camera
Flat batteries
a well known problem , this camera eats batteries there are high power (2950MaH) accus , those should be used with this camera even with 2700 MaH it is empty real quick
Mar 04, 2008 | Fuji FinePix S7000 Digital Camera
79 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
