Question about Dishwashers
No water? Unit is approximately 2 years old. Used once daily. Heats, but does not seem to be filling with water or spraying water through the cleaning chamber.
  • 10,865 Answers
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Jul 24, 2009
My unit heats up, has plenty of water, but will not spray, pressure is at 4
Sounds like a blocked nozzle. I would soak it in line Away or used a safety pin to clear it
Apr 28, 2016 | Vapor WhiteWing Steamer Canister Vacuum
How to clean sunbeam window air conditioner 5000 BTU
To ensure you are achieving absolute BEST energy efficiency, I would strongly encourage you to take the following steps:
1. Unplug your unit, disconnecting the electrical service from the unit.
2. Remove the filters from the front of the unit.
3. In a typical quart spray bottle, add 4 packets of UNSWEETENED Lemon KOOL-AID, fill 1/2 full with water, screw top onto bottle, shake well for 30 seconds, remove top and add water to near the top, screw top onto bottle and shake again to mix it very well.
4. Spray the INDOOR COILS with the above KOOL-AID solution until all of the solution has been used. The CITRUS Acid in the KOOL-AID will penetrate the coils and not only remove unwanted dirt, dust and debris; but it will also clean the bi-metal portions of that coil, making it SHINE.
5. Let the KOOL-AID set on those coils for a MINIMUM of 30 minutes.
6. While the KOOL-AID is doing its job, take the filters that were removed and rinse them under a faucet, ensuring the water is flowing from the back to the front of the filters in order to dislodge and remove as much debris as possible. It is acceptable to now spray the filters with either a solution of 50% water and 50% hydrogen peroxide OR simply spray with any household disinfectant/cleaner such as Lysol or Mr. Clean or similar product. Bump the filters against your hand to remove any additional water or household spray.
7. After at least 30 minutes, take that same spray bottle and fill it with clear water. Spray those coils once more with clear water to flush what ever may have been left within those tiny coils.
8. Add 1 drop of light weight oil to the fan motor and bearing.
9. Re-install the front cover of the unit; and then reinstall the filters.
10. Plug into an electrical outlet.
11. Turn the unit to the COOLING Mode and HI Speed Fan Mode.
Enjoy continued usage of your A/C unit.
This should be performed at least once each year in order achieve the highest EFFICIENCY of your system.
Sep 01, 2014 | Heating & Cooling
Air conditioners
Aug 25, 2014 | Carrier 39na40000634 Damper...
The Frigidaire pld2855 fills and drains but no water to the spray arms, it also heats very well, any ideas
it sounds like you have a problem with your spray pump it could be clogged up or it may have seized you will have to take it off and have a look at it
Dec 08, 2011 | Frigidaire Dishwashers
HI, I have a Bosch 500 series front loader 3 years old in daily use . My question is, approximately how long do the water hoses last and when should they be replaced? Hoping to hear from you soon...
the water hose will last for years how ever they may need to be removed from the washer and clean out the screens on the fill valves the main supply hoses do not wear out as far as i know.
Feb 12, 2011 | Bosch Washing Machines
Drip tray is filling up with water sooner than in
Hi
Either your grind is very coarse or your injector seal is bad. The injector is behind the brew unit and has 2 orange O-rings on it. See if you can wiggle the injector?
Dec 31, 2009 | Solis Master 5000 Espresso Machine
Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Mar 13, 2009 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
Owen Barnes
